Save 15% on Upgraded 2023 LED Turn Signal Lights
lasfit
official vendor
Attention all truck owners!
Exciting news from Lasfit! Introducing our latest T3 series CanBus LED bulb.
The T3 series offers a variety of bulb types that fit perfectly in your turn signals, brake lights, and tail lights. What's more, they come in dual color options - amber and red! The T3 series has it all! From 8.08 to 8.14, take advantage of our exclusive discount code "T315" to enjoy a 15% discount! Don't miss this limited-time opportunity. Get your T3 series bulbs now! T3-Series
Some highlights of T3 series LED bulbs
Upgraded Can-Bus Decoder System The built-in canbus decoder of T3 series LED bulbs increases the wattage to match the OEM computer inspection system and prolongs the decoding time, no error code, and you don't worry about hyper flash after working for a few minutes.
Softer Output Amber Lighting
Equipped with 16 high-light flip chips, the bulbs provide 2000LM and 24W of lighting, ensuring sufficient brightness while outputting softer light that does not cause glare or over-brightness.
Built-in Intelligent Temperature-Control System
Excellent Intelligent Temperature Control system will protect bulbs against excessive current and overheating and ensure a longer lifespan.
The T3 series will give you a lasting sense of security, while its light is also very gentle. I think it is a perfect bulb that you should not miss! Get rid of compatibility issues and experience the extraordinary!
Philthyphilthy
