Its actually designed for the Tundra/Sequoia engine bays, but I'm sure with a little determination it could be made to fit in the 4Runner.sblbdr said:urd racing in Ca has one.
OUTRNNR said:Its actually designed for the Tundra/Sequoia engine bays, but I'm sure with a little determination it could be made to fit in the 4Runner.
I got all excited when I read the title of the thread![]()
sblbdr said:I talked with the guys at urd and they said it would fit no problem!! The only thing they said is the intake would halfto be redone and they need a car to build one off of so call them and maybe they will hook you up.
Exactly. They would need to redo all the intake tubing routing. Basically, you couldn't buy the kit from their website, install it and go. You would need to custom fab some piping, which isn't hard, but is not exactly plug and play...sblbdr said:I talked with the guys at urd and they said it would fit no problem!! The only thing they said is the intake would halfto be redone and they need a car to build one off of so call them and maybe they will hook you up.
OUTRNNR said:Exactly. They would need to redo all the intake tubing routing. Basically, you couldn't buy the kit from their website, install it and go. You would need to custom fab some piping, which isn't hard, but is not exactly plug and play...
It would void the SHIT out of your powertrain warranty, no question. Ask URD about it and see if they'll stand behind their kit and pay if something does happen in the long term, though I doubt they would. I've probably crossed the line on my warranty and all I did was adjust the air/fuel ratio.
tomhaney1 said:Ya, I can foresee some apprehension on Toyota's part to cover my blower-induced engine failure! I envison it going something like this, "Honestly, sir I don't know why the piston shot through my roof, I was just driving to the grocery store..." Toyota's response, "Go fuck yourself."
I could just be ghetto and remove the thing if the engine blows!
Ok, so I am looking at the SC dyno results for the Tundra and it is for the 00-04. I wonder what it is for the 05+?? I wonder what the max boost is too. Damn it, now I have to call the bastards...
The horror stories are true for people who decided to up their boost. From my research the 2UZ-FE should be able to handle 5-6 lbs of boost reliably, which is what this kit is essentially providing.DiskDoctr said:ROTFLMAO!Laughed out loud at this!
I have the 04 V8 LTD 4Runner. Been trying on another board to get same answer: Can I use the Tundra kit, and what are the "right" tweaks/settings to not blow the engine.
Heard horror stories (read posts, no first hand knowledge) about the weak rods in this engine blowing up...
Let us know what you hear when you talk with them about using the Tundra kits with 4Runners.
Thanks!
-DiskDoctr
OUTRNNR said:The horror stories are true for people who decided to up their boost. From my research the 2UZ-FE should be able to handle 5-6 lbs of boost reliably, which is what this kit is essentially providing.
Looks like its a Powerdyne Centrifugal S/C:Casper said:any idea what type of blower they are using in this URD kit? Centrif? Positive Displacement Roots?
OUTRNNR said:Looks like its a Powerdyne Centrifugal S/C:
http://www.urdusa.com/product_info.php?cPath=1_2&products_id=1260198002
tomhaney1 said:I don't think a roots type blower would be good idea on a stock engine, especially not a V8. It is thermally inefficient and would be of no benefit for a V8 engine because roots-type superchargers produce their max boost at lower rpm's. That is what makes them more desirable to drag-racers and for smaller engine types.
rolla_dink said:the TRD IS a Roots type.
tomhaney1 said:That seems odd to me...Although there isn't one for the 05+ V8 so who knows!
