SC Oil Change
Major
Hi all. So I changed the oil in my SC today. I only found 2 pockets of oil in the nose cone with only 1 once each. So I only put back 2 ounces. Are there more than the 2 pockets in there. Should I add more oil.
Thanks John
I believe you will need 8oz of oil. I bought two 4oz GM supercharger oil and used almost both bottles when I changed oil on my sc. Mike
I thought it only took 140ml. Do you remember how much you pulled out. Did you fill to the plug
I bought 2 bottles as well but used about 1 1/2. I didn't drain and fill like you would the pumpkin or anything. I just put in what I took out. I did, however, sort of "fish" the tube around to in and out of the crevices.
If you are absolutely positive you drained it all out I'd find out what the capacity is and put the remaining amount back in so you don't run the risk of gear damage from lack of oil.
turbomikee
