SC or Xterra?
I have a 2000 SR5 Manual trans, with 4.56 gears and 285's. I am not supercharged. My truck is a LOT faster than the Automatic 4Runners my friends have. I can get rubber in 2 gears and get sideways easily. The rear Grizzly locker helps, but the point is re-gearing will make a big difference. Before I re-geared, hills were a problem in general.
If you haven't done the Deck-Plate mod, do that as well. It's about $10 and adds about 7-10HP and 18-20ft/lbs. of torque from 2000-4000 RPM, which is right where you need it most. Get a free-flowing cat-back while you're at it. That adds about the same amount of HP and Torque as the Deck-Plate mod. Get one of the non-baffled type of exhaust systems. Magnaflow, Borla, Jardine, etc.
I can leave small performance cars like the Acura Integra from the same era as my truck in the dust from stoplights. I shit you not.
Toyota quieted down these engines compared to the original in the T-100 due to their intended audience. They made them sluggish because of that. The auto trans doesn't do this engine any favors.
So, to summarize, re-gear and make the engine breathe better.
My .02
If towing is your main concern I don't think anything beats the 5.7 engine in the Sequoia or the V8 in the 4th gen. You can also do a lot of things with the extra space. Sleeping platform, etc.
Also I think you're supposed to turn off the OD or shift it into second if it is that bad. Rev it up. Italian tuneup! It cleans the cats.
Project SportRunner - Deck Plate Mod
It's been proven on a Dyno by multiple people years ago.
Edit: Gadget's findings, although he was SC'd, it still makes a big difference. As I said, Toyota quieted down the 4Runner, which hampered performance.
Air Induction
The quoted increases were around 110 mph. If you look at the graph provided from his testing results there is maybe a couple horsepower difference while driving at lower speeds. Even then I would be willing to bet that any horsepower or torque gains are minimal below 3000 rpm where most people and engines operate.
And it also stands to say if the engine could've been improved so drastically from such a small and cheap modification you can surely bet an automaker would do so as opposed to spending the time and effort to engineer the intake through the fender well and adding an expensive supercharger, especially considering these vehicles were designed with highway use as priority with advertised towing capabilities - meaning the proposed change would've meant less engineering, less materials and manufacturing, and ultimately cheaper production with more return profits. Well I say that, but we've all seen how the 3RZ suffers... and if the results are the same as an elbow delete (something that I advocate for) then I guess I don't have much room to speak on
I'd love to hear more about this "quieting down" cause I can't find a lick about it no matter where or what I search for
Toyota did a great job of quieting the intake noise. I've removed every piece of the stock intake and mine sounds like a shop vac in my engine bay when I start it up in the morning.
The deckplate is one of those 'try it and see if you like it' sort of thing. I saw a dyno chart once where someone had turned on ECT Power and done the deckplate mod and gained roughly 10 HP on an otherwise stock engine. I realize that's not much but it adds up if put on a cat-back exhaust, high flow air filter, etc. Maybe all one is after is turning their 183HP 4Runner into a 200HP 4Runner and that's enough.
I was in the same boat about 4 years ago. S/C my 3rd gen or buy something else (I was eyeing a GX470/460 as the replacement and building it up. I already had an LC80 and didn't want to to go back to it... too large for the trails I take, I didn't like its sloppy steering and too slow).
I also already lifted my truck and did a lot of modifications geared towards the type of OFF-ROADING I do. So I just S/C mine in the end.
That said, if you don't really offroad with any intensity (read: fire roads and the occasional rock) or haven't built up your truck much, I'd say you're better off going with the Xterra. Never drove one, but that's a great engine (as far as power, longevity seems to be OK on the newer ones?) and it'll probably be more civilized, relatively capable and a good support community.
I do suspect it will have more issues compared to the 4runner, but not enough to break the bank (as all Nissans seem to).
I'd get the Pro-X... but those are going for a crazy premium. If you don't have a RR diff lock now, than any 4WD Xterra would be fine I'd guess.
On this mod, I saw the same dyno... not sure how valid it is, HOWEVER, I did the mod anyway after I S/Ced mine... figuring it was sucking in more air due to the FI.. so it couldn't hurt it. Does sound a bit throatier, could be faster, not sure?
Just have to make sure to seal it up before any rainstorms, lol.
Tundra 5.7 for towing all the way. Guys where I work love this motor. Otherwise you want a V8 4Runner. All the other stuff is going to be expensive bandaid fixes for a vehicle that was never meant to do heavy towing.
Trailer weight and vehicle weight need to match up and so do hitches and anti-sway equipment.
What's crazier is that there is a supercharger for the 5.7. It is already a beast. That thing will eat a Raptor and do 13s in the 1/4mi.
Yea I don't think anybody is buying an Xterra for towing. Lol.
AndiGarage
