FIRETAIL-AR
I have a 2005 V8. My question is if SCII will display transmission temp. I have read many threads, but there does not appear to be anything definitive. Thanks.
I have used “T” fittings and Oil Temp & Engine Oil Pressure PSI “Manual Gauges” to monitor 70s VW’s engine oil and Jeep Wagoneer’s transmission oil and engine’s oil psi. I established norms on normal temp days during normal operations to mark my red lines and operated from those standards. Such as, if the VW’s oil temp ran 225 degrees on a normal hwy drive 75-85 degree day in TX. I knew to back off MPH/RPM @ 250–275 oil temp on a 100 degree day. They worked well with engine oil temp and pressure being the most notable and real concern. The “Old Saying” was when the Red Light came on back then, "It’s Too Late"! jow
A few other posts around have this information for the Scanguage:
Trans Temp
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
This doesn't work on Gen3 but supposed to work on Gen4. I haven't tried it yet.
