Schrockworks bumper
4RunnerTEXAS
Does anyone know if the Schrockworks bumper with the light guards will be able to fit my Rallye 4000s? I emailed them and he said he was pretty sure they would, but I was wondering if anyone had that setup or knew of anyone so I could be 100% certain. I really want to get this bumper, but didnt want to waste my lights if I cant use them. Thanks in advance.
what are the diameter of the lights? i have seen plenty of light force blitz 240's and those are pretty beastly.
well i do beleive though that the light force's mounts make the lights stick out a little forward... i dont know about the hella's. if the hella's are straight up they might touch the hoop... ask someone with a schrockworks to measure the center hoop height, that should def. tell you if they will fit or not
Yeah thats a good idea. If anyone has one on here can you do that please? lol Thanks.
On my bull bar from the bumper to the bottom of the hoop is about 8.25~8.5 inches.
Thanks so much for your help! That may be a little tight, depending on if they stick out enough to clear. I may have them like someone else mentioned in another thread bend the bars out a bit. Thanks again.
I also got 8.5 inches. I have the standard hoop they offer, nothing custom. Like everyone is saying, if you want it put the order in now. The wait is painful. Imagine getting excited, waiting, reaching the point of forgetting you ordered it, remembering and getting excited again, giving up on it.....then it comes lol.
lol great. Thanks for your help. :thumb3:
You can ask to customize the hoop a little before the build it, so you may want to look into that. I ordered mine with the prerunner center hoop only, it's not an option but I asked and they did it so....
well you can only do the center hoop... the thing that is custom with yours autbond is that its slanted out more
Yea, it is slanted out more and it is a little shorter also. I would assume that you could ask them to do anything with the hoops that you wanted. The hoops are the last thing they do before powder coating so...
The only lights that big that I know of which will still fit are the LF 240's. The shape of their mounting brackets/supports push it out far enough to clear the hoop. However, on 06+ 4Runners you have to pull them down to open the hood because the grill hits them otherwise. Anything with a straight mount will not fit.
Here you can see that they sit a little lower than the bumper mounting surface, and a little higher than the hoop:
20100528-edit2_DSC2623-1.jpg~original
