SCS F-5 wheels 16x8
Personally, I prefer the look of 3.5" bs on a 3rd gen for some wheel/tire poke. If you like more of the flushed look then consider 4.5" bs. Otherwise 3.5" bs with 265/75/16 would look great with a mild 1.5" lift.
Vin,
Would the 3.5" BS 16x8 with a 265/75/16 fit on stock 99' height(1" raised on the 99).
I want it to have some nice poke but it's a limited with the chonk fender flares and I'm not lifted (yet).
Thanks!
+0 is better suited for a stock to 1" lift.
Thanks for the quick response!
What limitations have been found? Rubbing on the flares? I plan to do a 2" lift likely next year. Could I get by with cutting some plastic to clear, or is it a no go until 2" lift?
I'm just a big fan of these wheels with a flush look.
Here's +0mm offset with 285s. See how flushed that is. -25mm would poke more.
If you're not afraid to cut and trim as needed then you can probably make it work with a mild lift.
Guess the Wheel and Tire Specs!
AVvXsEgAt24ncfLUiH6R1dEyZLxx0g6Pu9W_d5GrFYz7aNosWI_IZ6HiIdg_1-OSBlEVbETo3pYX4X-uryb84o7xPtys4aukFN-qgGvUs4AoaQrfIOQY7trRutnKZw9ssm_iES23VM24xzPTd9HXjMRngAmqsbhvI-s9gSS0TFsRnc4XAbaUZj2tjxPFlmHO=s4896
2001ATL
