SCS F-5 wheels 16x8
Vin,
I have a 2000 4Runner with 285/70-17 (33s) tires coming later this week...
I might go with 35s in the future. Of your two 17" options which one would you most recommend for ease of fitment?
17 X 8.5 6 X 139.7 4.30" -10mm
17 X 9 6 X 139.7 3.50" -38mm
Vin,
With 285/70/17 I would recommend the 17x8.5 option. 17x9 -38mm is extremely aggressive for a 3rd gen 4Runner especially with 35s. If you ever decide to step up to this size, I would recommend going with the 16x8 -25mm and 315/75/16 tires.
Ease of fitment and 35s don't really belong in the same sentence :eyebrows:
Vin, much appreciated on the fast response, and some humor too.
If I were to go with the 17x8.5 wheels, what might be needed to fit (no rub) the 285/70 - 17 tires?
What do you think would be involved in getting 35s to not rub on 17x8.5s?
If it helps:
Front: Suspension lift (King) approx 2" with SPC UCAs
Rear: Suspension lift (King) approx 3"
Thanks much for the help.
hey Vin. Looking to get a set of F5's in 16x8 for my 01 3rd gen with the larger fender flares. I am going to overhaul my suspension with a mild bilstein/OME lift. I want the wheels to sit flush or slight outside the fender. Would 3.5BS be ok? Anything I need to worry about in regards to fitting 265/75/16's? Thanks ahead!
With the flares, I would recommend going with the 3.5" bs option. That's a great tire size choice for a 1.5-2" lift.
Vin, I attempted to PM you, but I'm not showing the message in my outbox, so I wanted to reach out on this thread. I'm looking to purchase the Stealth 6 17's in jet black within the next few weeks for my 2017 SR5. When will they be in stock next? I'd like to be waitlisted if some will arrive in January. Further, which lugs will I need to run?
I like F5s and have 2.25" lift already. Which backspacing you'd recommend for 255/80r17? I was thinking 3.50 to get wider stance and to avoid spacers. I don't mind doing bmc.
Looking for the right size F5 on my 5th Gen
2.5” lift upfront with camburg UCA.
I like the 16” wheels, will they clear the caliper?
I just did a little research on the Limited caliper size and I'm getting mixed reviews. Some folks are reporting that they have the larger calipers like the Sport Edition and some are reporting that they have the standard calipers.
One way to find out is by measuring your rotor size. If it measures around 12.5" then yes the F-5 will clear the calipers. If the rotors measure around 13" then you have the larger Sport version calipers which will not clear a 16" wheel.
Any update on these fitting limited calipers? No scs whees in 16” will wrap around the 13” rotor? Offset or any way of gettin it done
Stealth Blue F5 16x8 3.5 BS
I've got the blues... Can't wait to mount these tomorrow... Thanks again Vin!
hey there [MENTION=88453]SCSPerformance[/MENTION] – just ordered a set of 16x8 3.5s. wanted to confirm with the source that they'll accommodate the 231 Tundra brake upgrade without grinding or anything :)
Yes, they will clear. There's no need to any caliper grinding whatsoever.
Checked the website for some F5's in 16x8 and 3.5" BS, out of stock. Is there any waiting list to hop on or can I pay in advance? Is there a ETA on next shipment?
You can subscribe to our Toyota 4Runner Forum - Largest 4Runner Forum - View Single Post - New Inventory subscription thread if you haven't already. We will make a post/announcement 1 or 2 days ahead to let everyone know when our website will be updated with new inventory. They will be sold on there on a first come first serve basis.
Hello,
I currently have these stock wheels.
I think they're the 5 spoke flower wheels that come with the 01-02 models.
Does ALL SCS rims models on this page fit??? TOYOTA – STEALTH CUSTOM SERIES™
I have the 231mm Tundra brake upgrade. 5100 Bilstein shocks all around w/ OME 881 front and 906 rear
P265/70R16 Michelin Costco Tires. I want new wheels where I don't have to use a spacer/have rubbing/etc.
The size should be 16x8 w/ 6 lugs so I narrowed it down to these 2 at least for the F5 Series but I have no clue which one to get with the BACKSPACING/OFFSET and everything being confusing to me.
SIZE ||||||BOLT PATTERN||||||BS||||||OFFSET||||||WEIGHT
16 X 8||||||6 X 139.7|||||||||3.50"||||||-25mm||||||18lb 2oz
16 X 8||||||6 X 139.7|||||||||4.50"||||||+0mm||||||18lb 13oz
BillM777
