SCS Stealth 6 wheels 17x8.5
SCSPerformance
Official Vendor
Please PM/email me for a shipping quote. Feel free to ask me any questions that you might have. All of our wheels are hubcentric and designed specifically for Toyota trucks/SUVs.
The timeless quality of the Stealth-6 Model is the result of endless hours of refinement. Our team tweaked multiple design versions, finessed millimeters of lines and curves to achieve the final clean lines in the design. The split 6-spoke design is reflected from our philosophy of understated design and our mission to achieve form and function. Get ready to hit the trails and the show scene with the stylish Stealth-6 Model.
Tested and confirmed, the Stealth 6 will fit 4th gen. 4Runners with the Sport Edition calipers.
Matte Dark Bronze
Matte Jet Black
Matte Gunmetal
3E3C83F2-F135-456E-83B5-32022268E2DD_zpse0xexoqa.jpg~original
matte gunmetal...availibility? like order at the website and have how quick? commercial address 72032. I really like them...will be going on a silver 2012 SR5...appears a direct fit on.
thanks!
john
thanks!
john
Hi John
Matte gunmetal is currently in stock and ready to ship. It is a direct fit and you should not have issues whatsoever with the setup. Check your PM.
Hey just to be sure, the silver 4Runner pic wheels are matte gunmetal right? Do you have any pics of the Gloss Jet Black mounted on something? preferably Tacoma or 4Runner, I'm torn between the Matte Jet Black and the Gloss Jet Black and want to see the gloss mounted. Thanks!
The silver 4Runner posted above has the gunmetal finish. This is the only picture that I have so far from a customer for gloss jet black.
Let me know if you have any other questions.
This is probably a dumb question but... You mentioned not needing ET lugs, does that mean I could reuse the stock lugs?
Evan, that's not a dumb question at all. You are correct, our wheels do not require ET lugs. As a matter of fact, ET lugs won't even seat properly with our wheels. Most other wheel companies produce their wheels as a "one-size fits all" type of deal. This means that their hub opening is larger than needed to be able to fit various makes and models and likewise their lug opening is larger than needed to fit the various stud sizes on different makes and models.
The hub opening on our wheels is designed to fit like a glove on Toyota hubs and the lug opening has very little play. You will have to use bulge seat lugs with our wheels so to answer your original question, the stock shank/mag lugs will not work with our wheels.
Thanks. You must have a much nicer monitor than me.
I'm going to start saving my pennies for a set of these. Did I see a TRD center cap in another thread or was that a different wheel?
;):. The TRD center caps fits on the Stealth 6, but b/c the cap is a flat style cap(ours is dome), it does hit the dust cap on the front hub. It can me made to work, but you would have to run a 1/4" spacer on the front to get the needed clearance.
That's too bad but it shouldn't be a deal breaker for me. The main reason I want these wheels is to get the tires where I want them without using spacers.
patnewton
