SCS Stealth 6 wheels 17x8.5
That's too bad but it shouldn't be a deal breaker for me. The main reason I want these wheels is to get the tires where I want them without using spacers.
I think our BS is right on with these trucks. It provides a wider aggressive stance, but at the same time it's not overdone. Our center cap is very low profile. It's not something that you see too often on truck wheels. The overall design of the wheel and detail looks a lot better in person.
Any possibilities of a brushed aluminum wheel in the near future?
*hint, hint* An aluminum bead lock option would be nice! :D
Do you have a pic straight from the back or front (no lifted 5th gen LED/SR5 with 265/70/17 tires)?
I’d like to see how much the tires stick out.
Sorry, but I don't have any pictures of what you're asking for. This is the closest shot that I currently have. It's lifted, but it can give you a sense of how the wheels/tires will sit.
S6_CourtF-4.jpg~original
Matte Gunmetal is currently out of stock. Our next big shipment is coming around spring time so it's going to be on backorder for about 60-90 days.
i have a 4th gen with xreas and wanting to know how big of a tire i can run on these rims without having a lift
With no lift, you'll need to do some decent trimming with the stock 265/65-17. With stock wheels plus 1.25" spacers and 2" of lift, I had to do significant trimming of the mud flaps, the corner of the bumper, and move the fender liner forward with only 265/70's. The sexy Stealth 6 will stick out a little bit further than what my set-up does.
Doozi is correct. 265/65/17 will require the least amount of trimming, but ideally you would want to use at least a 265/70/17 tire to achieve a beefier look. This will require more trimming and removal of your mud flaps due to the aggressive wheel offset.
delislerebecca
