Seeking tie rod end advice 2007 v8 lmtd
mavrick1903
Rig is 2007 v8 limited. Put new front coil overs on (King, feel great) and the alignment ship (Tires Plus) is telling me the following:
Right Inner tie rod end is nearing end of life
Upper right and upper left ball joints are nearing end of life.
I'm not sure they are right about the ball joints since they suggested replacing the control arms and I've got the Icon version UCAs (the Total Chaos tubular type).
Let's presume they are right about the tie rod ends though. I did all of the suspension work to install the UCA and coil overs (to put in the Icons, and two years later, to replace those with King remote reservoirs, as well as springs/shocks in the rear). So, my question to the collective is:
Can I replace the tie rod end in the driveway.
Who's should I use. OEM or aftermarket (and if non-OEM, which)
Should I be doing just the one offending end, or both inner/outer? or inner and outer on right and left?
Thoughts?
If you're going to replace your tie-rods, might as well do both sides at the same time, so that you don't have to worry about it down the road.
At about 100k with a couple of mild off road trips, I replaced the following:
-Both LCAs
-Both inner and outer tie rods
The inner tie rod on my driver side was loose to the point that my alignment shop refused to align my truck until it was replaced.
I bought moog for mine when I did my outers. For the price you can buy a complete assembly to carry as a spare as well. Which I do along with an axle on those LONG trips.
