Settings
mlrff
Member
So I just picked up my 2021 limited and I'm trying to change the lock when put in gear to lock when speed is reached . The owners manual explains how to do it but no luck it wont change. Any help as to what I'm doing wrong.
Most of those settings require the dealer to use his Tech Stream unit. Just have them change the settings the next time you go in for maintenance. I have had my dealer do that and they did not charge me anything.
So can you detail your process and maybe we can help you.
Gotta know what you are doing to help.
I’ll go check mine to see if I can change my settings...
EDIT:
Menu > Setup > Vehicle > Vehicle Customization > Door Lock Settings > Automatic Door Lock > By Speed
Mine is changeable!
So turn the ignition on put in neutral for speed or park and then hold down the lock button for three seconds.
So my process was done on the infotainment system on my 21 TRDORP.
Appears to be different than your limited.
Ambrose67
