shaking under load at high speed
spmarfatia
Hello everyone,
Typically I get most of the info I need just by reading posts here, but I think the time has come to post the first one.
I have a 98 limited with 160K on it. On one of the recent trip of about 250 miles, I notice shaking(violent) under load at high speed. Load meaning just grades on the highway 95 in CT. They are not bad but can be long, multiple miles sometimes. so, eventually the car would start to feel the load and then when the time comes when it is deciding if it is time to down shift or continue to work hard on the top gear, this is when the shaking is bad. But I have also seen this when the car in fact down shifts, and the cruise control being on, tries to get back to the cruising speed, lets say 70-75mph, with 3500-4000 rpm, the shaking is also there. so with 4K RPM, there shouldn't be load on the engine, if anything, it is over raving at that point give the work it has to do. (ie maintain the 70mph which it almost did at 2500rpm)
I am trying to figure out if it is transmission or engine. (doesn't seem to be suspension or tires, as it is only under load and not constant, tires are new with less than 10K on them. New Bilsteins with 15K on them.)
I owned the car for the last 50K miles. Haven't done any tuneup or changed tranny oil yet. (haven't even done the timing belt yet. I heard these are non-interference engines.) I don't like to over maintain my cars. like, new plugs/wires every 15K, new tranny fluid at every 15K etc. so, please don't tell me to do any of that. I agree that vehicles do need to be maintained though, at proper intervals.
Could it be bad gas? (I filled up at a station in MA that had 10% ethanol sticker on the pump. how do these 3rd gens like the ethanol?)
I've had engine misfires on my previous cars, and I could usually tell if its the engine misfiring/missing. this doesn't seem to be. Also, don't know if engines missfire only under load etc...
Thank you.
Sam
If i understand correctly it could be a bad ujoint. There are a couple threads about it. is that the type of shake you are feeling?
I think Asa is right. Check your u-joints, typically for me vibration under load at higher speed is a u-joint about to do a nifty trick.
Hi,
Don't feel the vibration at the steering. Mostly in the center and kind of center front of the vehicle. so through the seat. Get the feeling that it is through drive train.
Also, reading through threads on UJoints now.
Thanks.
Can't hurt to do wires also
Esp since you only need 3!
plug_wires-1.jpg~original
Do I need to get the expensive $11 platinum spark plugs or $3.50 nickle will be good enough?
What is factory installed on this truck? Nickle or Platinum?
Thanks,
Just replaced the spark plugs with ones from Toyota dealer. I think they were denso(nickle). Replaced air filter too.
Haven't had a chance to test the load under high speed yet, as what I noticed was in long slopes on the high in CT, far from where I live. So, won't get to testing them until I am out of town again. There aren't any long slopes close to the home.
Do notice some smoke when starting for a first couple of minutes and exhaust sounds like little too much bass. typically the sound of when the exhaust is leaking, but in my case there is no exhaust leak. (This was like this even before I replaced spark plugs, so not to confuse with starting now after the plugs were replaced)
The smoke/smell when starting and exhaust sound like that, does that sound like a familiar problem to you guys? (I do see lot of 3rd gens with similar sound when passing by too, so may wonder if it is known/common issue.)
Thanks.
Will check the U-Joints.
Went on a 40-50miles trip today after changing the plugs. So far looks promising. (could be just psychology)
Thank you everyone for help.
