I wouldn't recommend, especially if you have an A/T. Here's a general rule of thumb: try to shift as little as possible... For example, when you find a parking space, try to find one where you can park in the next slot in front of you, this way when you leave, you can just drive off, and not have to go from Park to Reverse, stop, then shift to Drive. One of the old school ways to test if a transmission is worn, is shifting (while stopped) from P to D, wait a moment, then shift to R, wait, shift back to D, repeat as needed. If there's no loud clanking then the A/T is likely in good condition.
If you really want to save gas, then check out this segment from Mythbusters. It's about drafting behind a semi-truck. Here in Los Angeles, tailgating is normal due to constant heavy traffic, etc. But do so at your own risk. Semi drafting really works, helped improve my V8 2wd from 22mpg to a whopping 24.5mpg, based on mostly highway driving. If you do try it, make sure you pick a semi that has decent mud guards on the rear tires. I try to keep at least 3-4 car lengths between me and the truck, seems a lot safer than driving behind other cars / suvs that tend to brake more suddenly and more frequently.
DRAFTING SEMI
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/lttgT1XZVvE&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/lttgT1XZVvE&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
