Shock Advice '02
rocdoc
I'd like to stiffen up my stock '02 limited.
Thinking about new BFG All Terrain T/A's on the stock 16"rims. The stock vehicle always looks like it's butt is low. It needs a little stiffer shocks in my opinion and would love to see her up a touch, maybe an inch?
Any suggestions on shocks, for mild off road and on road? Will stiffer shocks give me any lift on the rear or do I need a lift kit? If I go to 17" rims will I need a lift kit for clearance?
Thanks in advance.
rocdoc said:
... It needs a little stiffer shocks in my opinion and would love to see her up a touch, maybe an inch?
... Will stiffer shocks give me any lift on the rear or do I need a lift kit? If I go to 17" rims will I need a lift kit for clearance?
Thanks in advance.
Shocks do not provide lift, suspension does (air shocks aside).
If you use larger rims with the same size tire, the overall tire height should be the same, so clearance shouldn't be an issue.
"The Toyota Corona is an automobile manufactured by the Japanese automaker Toyota between 1957 and 2002. While in the United States it was classified until 1983 as a compact car and later on as a mid-size car, in Europe it was always regarded as a large family car.
The Corona became massively successful in export markets: confusion easily arises because Toyota (like Volkswagen with their Passat and Mitsubishi with their Colt) applied model names inconsistently in different places. Following the 1969 parallel introduction of the Corona Mark II (which in certain markets mutated into the Cressida in 1973) there were disparate models sharing the Corona name. As time went by, models branded in much of Asia as Coronas turned up in European markets as Carinas, while ten years later in North America the Corona was successfully replaced by the larger Camry. In addition, because of the similarities in names, it is a very common mistake to confuse the Corona with the much smaller Toyota Corolla."
______________________
i love Autopartswarehouse because Autopartswarehouse is the best
