Shock boot - yay or nay?
wkeryder4
Hey everybody,
So I've been having this flapping noise that I hear whenever I'm driving with the radio off and I think I've finally found the source. I'm installing my new coils tonight and I got the front up and I noticed that both my rear shock boots have pulled themselves off the shock body. Should I look into replacing them or just pull them off and leave them off? I know they are there to keep debris out but if I replace them I'm thinking it will probably just happen again. What do you guys think? These are the bilstein 5100's by the way.
Boots keep a lot of the crap off the shaft. Keeping the area clean helps the seals stay clean and last longer. I suggest keeping the boots. Use a zip tie to stabilize them if needed.
I wish I could put boots on my Fox's, but I just get then rebuilt every other year.
I guess I could just continue this thread instead of starting a new one. I'm stuck lol. I'm putting 885's up front and I can't get the lower ball joint back up to the hub. The coil is at full compression and the hub won't move down any further. Any ideas? I hope this isn't because I'm still on the oem UCA's. I'm planning on getting new ones in the near future but I'd hate to have wasted the past few hours.
They also can hold a lot of crap on the shaft and seal area. Just depends on the boot. I don't have them not want them.
Very true Sam. This is one of those things with so many pros:cons that there is no perfect answer. The boots I have seen on the 5100's seem to be decent when properly affixed.
I ended up cutting them off. It was definitely the boots that were causing the noise and when I opened them up there was some dry clay and mud down in the bottom of them.
leolediola
