i've been lurking for a while now, and i've noticed that there are a few folks from the area. i brought my 98 limited 4wd v6 147k to a shop recently to get an alignment and check the belts (making a bit of noise at idle). he indicated that the belts look to be original and wanted close to $1300 to replace the belts, wp, arms, seals, etc. i talked to the toyota dealer just south of denton and they said they didn't have a timing belt 'kit' per se, but that to replace the aforementioned stuff, it would be in the $900 range. she said they usually replace the belt, then look at the other stuff and replace it if needed.
from looking around on here, i know $1300 seems way high, and that it seems that a dealer would be aware of the 'kit'. if this is truly the original belt, then it would probably be a good idea at this point to replace the whole lot. basically i'm looking for someone with some experience with these vehicles that can a) determine if the belt is indeed original and b) provide a decent quote and do a good job.
