Should I Buy a V6 or V8 for Off-roading?
pipo6007
Just as the title states should I buy a V6 or V8 for off-roading? I’m considering both options right now and looking to pick one up very soon.
I currently have a 2006 2wd with 185K and it’s a V6 but it’s been my daily driver for almost 14 years.
Buying a second one 4x4 to lift and just to take off-roading. What should I look out for on both options. Any downside to the V8 off road or maintenance wise? Should I stick with another V-6?
The V-8’s are 2003 and V-6’s 2006-2007. Similar mileage, wear and prices.
I vote the V8. That's what I went with when I got my 03 Limited. Full time 4wd is nice. The V8 uses a timing belt instead of a timing chain, replacement is every 90k miles or so. More hp, more torque. The 2UZ motor is proven to go a million miles with proper maintenance. Gas mileage is pretty much the same between the 2 motors from what I have read. You'll appreciate the extra power of the V8 for sure.
I've been wheeling my V8 for a few years now and love it. The torque is there to turn my 35s with zero issue, and its also nice to have that power on the highway without having the re-gear. You'll be even more pleased with an aftermarket exhaust :) I love having a roar.
The AWD is also groovy to have here in CO during the wintertime, always has my back!
Awd
So the V8 is all time 4 wheel drive and the V6 is not? I see the same dial in both so do they work differently? Never had a 4x4 so new to this set up. As far as maintenance the timing belt is the only difference?
V8 are all full time 4wd. The selector stays in 4hi unless you need 4lo.
V6 are 2wd normally. From there you can select 4hi or 4lo.
They both use a similar selector knob.
Timing belt in the V8 is the main difference, yes. Overall maintenance will be the same otherwise. They both have a front differential and a transfer case so you will need to add those to your maintenance chores.
Everyone loves more power, and of course everyone with a V8 thinks we all need one. I don’t rock crawl but my V6 goes everywhere I want to go. Watch a couple of videos on my YT channel (linked in my sig) - if that’s the off-roading you’re thinking about, the V6 will be more than fine.
IMO, the V8’s advantages are insignificant if you consider the relatively few times the engine may really make a difference, and from what I’ve read, you’ll be wishing for a V6 every time you change your oil and when you’re dropping big $ on a timing belt change every 100K miles.
Bottom line: either one is a great offroad truck.
Wut?
Oil change on the V8 is simple. Timing belt every 100k is not that expensive (DIY for like $300 MAX) and easier than the timing chain on the V6 from what I have read.
V6 for reduced weight offroad.
V8 for a bit more torque with larger offroad tires when driving onroad.
Both motors are fast enough, or both are slow depending on what vehicle you come from.
Read any of the other V6 vs V8 debate threads they will all echo this one.
I second this! Plus, with the V8, when you want to pass someone on the highway, it's so much easier. Stepping on the gas peddle with the V8 lets people know know you're not in the MOOD for a Sunday drive. Upgrade that V8 with headers, y-pipe, muffler, and you'll have a BAD ASS 4runner!
Wut?
Aren’t there numerous posts from people complaining about having to take off a skid & crawl under the truck to get to the oil filter on V8s? Granted, that may meet the definition of simple but I was speaking relatively & it’s still harder than the V6.
Fair point on the timing belt but what percentage of owners have the skill, time, & confidence to do their own?
I meant no disrespect to the V8 or owners of them. My intent was simply to provide some counterpoints.
I’m fine with the V6 but have never driven a V8 one.
The 4hi without the center diff locked is annoying, possibly the same in the all time 4 V8. Spin or slip on snow or ice and it’s computer nannies galore which makes me feel not in control.
Probably get slightly better gas mileage with the V6 and and less drag/loss from constantly turning the front drive system
Dropping the front skid is only 4 bolts if you still have the factory skid. And it's not heavy at all. Filter is easy to access, easier than on my 1st gen Tacoma! It's right at the front, on the driver's side. I've read where some people have even modded the skid so they don't have to pull it to access the filter. You could even just lower the front of the skid only and get to the filter.
As for the timing belt, when you start getting into vehicles that are hitting this age, you either need to make sure you have the funds to pay someone to do the maintenance work or learn how to do it yourself, IMO. The V6 and V8 are probably going to be similar cost wise for the timing belt/chain to replace.
The V6 and V8 can operate in the exact same manner, except that the V8 can’t be switched into 2WD. All other AWD/ 4WD modes and capabilities between the two are identical.
I don’t have a lot of counterpoints against a V8, I have always wanted one myself, but the V6 has served me VERY well as a dedicated off-road truck. I wouldn’t let any of this hold you back if you find a good one at the right price. If my choice was between a very well taken care of V6 and a beat up V8 that needed a lot of work to make trail worthy, I would take the V6. I only say this because a good condition V8 can come with such a premium at times that you can get a lot done for the price delta.
Most all my serious off-road driving is done in low range. In low range I don’t think you would even come close to missing the V8.
I like that there is a little extra room under the hood for things like air compressor and dual battery.
I like that it’s a timing chain
I like that oil changes are overly simplified.
I like that I can be in 2WD.
Weight
The only thing that leaves me wanting a V8 these days is the fact that it’s a V8. I’ve started to care a lot less about any of the disadvantages/advantage between the two because any limitations I thought I had were all mental. Driver skill tends to be the limiting factor off-road, not power.
The chain is supposed to be good for the life of the motor… I have over 200k (single owner) miles and it’s never been touched, or needed to be touched.
Any time I see V6 owners who have experienced timing chain stretch generally neglected to chain oil on a regular basis. Buying used you might not have history here so there is that.
I do agree with what you said about age. When my 4th gen turned into an off-road toy / project truck, to justify keeping it I started doing all the work. To a degree I think it was necessary for myself as I really understand my 4Runner much better than I did before and have more confidence fixing something should I experience trouble on the trail.
I have a v6 too. I am the 1st owner and now have around 149000 miles. I've used synthetic eversince. It's my daily driver and I don't off-road it much. Just a few times when I went to the beach. It's always in 2h 90% all the time. All the rest is when it's snowing or at the beach or raining. Do I need a V8 for this purpose?
No, you don't. But that's not the point. The OP asked which way everyone thought he should go between buying a V6 or V8 truck given that everything else was about the same between the 2. You already have a V6 truck that works for what you do and you're happy with it. If you were in his shoes and trying to decide between the V8 and V6 for another truck, which way would you go the second time around?
Thanks for all the replies guys. Learning the differences between the them is helping my decision process. Keep the info rolling.
I’m use to my V6 and no timing belt replacements and I also change the oil myself. Removing the skid plate doesn’t seem hard at all so I don’t think that’s a deal breaker.
There are three that I’m considering. Two that are 2003 V-8’s with 125K miles and 175K miles and are around the same price. Both are limited with leather and sunroof. But one has a cracked dash that looks bad so I’ll probably pass on that one.
The V6 has been in one family since new and it’s a 2007 with 180K miles. No leather or sunroof.
Prices are very close. Haven’t seen them in person yet but might make sometime this week to go look at them.
Also to consider is that I swap my parts to the one I buy saving some money having to mod it right away to use.
Will the 2003 V8 have any issues with that? From what I see I think not.
Thanks for all the info.
7ron
