GHARP57
That quote is insane and I hope they were wearing masks when they gave you the estimate. They're wanting to change a bunch of stuff that probably doesn't need changing and double or triple charging for the stuff that does. For example, cam seals: You just replaced the TB. If the cam seals were leaking you would have seen it. Another example is the rear brakes. They want an inflated price to replace the shoes then another inflated price to change the axle seals and brake cylinders, then another 180 bucks to bleed the brakes? Last time I checked brake bleeding was part of the job. $856 to put on a new transmission pan gasket, then another $120 for a transmission flush? They definitely want you to go away because you'd have to be crazy to pay these prices.
The are talking about the rear cam seals they are half moons that ALWAYS leak after so long.
He said oil pan gasket not trans pan. you have to take the diff off to get to the oil pan.
Look I know some dealerships are out there will **** people. This place does not look like it.
