Should I step up to a 285/70/17?
Xetabur
So a few weeks ago I had a lift and tires installed. I went with the Falken Wildpeak AT3Ws in 275/70/17 and I’m regretting not getting a larger tire.
Edit-285s were ordered. Install is 10:30 tomorrow.
Glad I'm not the only one. Same situation installed Kings with 275s. In the process of ordering 285s at the moment.
I have until 2pm today to pull the trigger so they can be installed in the morning.
Any idea how much bigger the sidewall is on the 285 vs 275?
I’m open to a skinny tire with more sidewall if anyone has any suggestions.
I will be keeping the tires and installing them on my limited once I get wheels for it.
Sounds like you have a back up plan for your 275’s so I would say go ahead get the 285’s or it will just keep chipping away in the back corner of your mind. I knew this going from 265 to 285. I originally thought about 275 but skipped it and went straight to 285 and I’m glad I did. With that said, theres nothing wrong with 275’s but it wasn’t the overall look I wanted to achieve on my rig. Everyone’s personal taste and use for their own rig is different. YMMV
285's in some brands such as Cooper (current tire) weigh the same as 275's in the popular KO2 choice, 55lbs.
Ride like glass and love them.
Here is a clip from my tire decision excel document!
275- diameter 32.4
285- diameter 32.8
255/80 would be a good choice for you - 33.1
You do realize that with 285's you'll have to do a fender liner mod, may have to remove mudflaps, and could possibly need a body mount chop?
I would say yes to going 285, but like a few people said, I would recommend you wearing out those tires before going 285s.
Sell the tires you have, and upgrade before you wear the tires out. I just sold my Nittos with 3k miles on them for $150 less than you can buy them brand new for.
If you need the BMC, skip one night of NetFlix and knock it out; no big deal.
The fender liner mod only takes 5 minutes.
Not true. The keyword is maybe on all. I didn't do any of that. Many people don't have to do any modification to get 285's to work. Since the OP is running trail edition rims its even less likely he will have to do anything to get it to work properly.
Having been through cooper 285 tires I am now back to KO2 275s
Off-road and look wise, no doubt 285s help. But for the majority of the drive time (tarmac) it was just too cumbersome for my taste.
I’m getting to the wire here and I’m still undecided. Grrrrr
Thanks for all the responses so far.
I have 285's on my 17 SR5.
1½" spacer on top of OEM struts.
They slightly rubbed the inner fender liner until I moved the liners, about an inch.
Not stock wheels so no idea what offset they are.
Sent from my SM-G955U using Tapatalk
