Shouldn't all the wheels be spinning in 4wd?
wisedog
Got stuck in some heavy snow (03 V8 limited) and with the center lock on(and off) the driver rear wheel was not spinning, the other 3 were. With the trac system off i would assume all 4 should be freely spinning?
Somewhat common misconception. A differential between 2 tires will allow the two tires to spin different speeds so you can turn, unless you lock that differential. Our trucks have 3 differentials and you only locked the middle one meaning at that point, the front and rear differentials will each see half the total power from the engine, but they can still distribute their power to just one of their wheels.
Your driver's side rear tire must have gotten caught up on something, or the passenger's side rear tire was on ice so all the power still got distributed to that free-spinning tire. That's why front and rear differential lockers are handy even if you have 4wd.
yeah I knew the center diff was not a true locker but i figured the rear wouldn't just put power only to one wheel.
I believe center diff lock does exactly that.....locks just the t-case so it distributes equal torque front/rear. Without it you could have your rear wheels stuck in a mudhole or off the ground. They'll spin like mad and the front tires wouldn't be pulling at all (or at least very little).
With the center diff locked front and rear pull equally (more or less). However, the power distribution between left and right depends on traction....so you can be 4wd, center diff locked, and still easily stuck with one front and one rear tire spinning......
Sounds like it's working as designed. 2wd is normally one wheel spinning. 4wd is normally 2 wheels spinning. There are various exceptions.
Rear locker would lock in the spider gears causing both rear wheels to spin at the same speed.
An incredible amount of people do not understand this. Almost every vehicle ever made is one wheel drive or 2 wheel drive when in 4wd. The only way you get power to all wheels is if you have lockers which only came stock in some international (scouts/pickups) and jeep rubicons (selectable) and some landcruisers maybe a handful of others, some vehicles have an optional rear limited slip and more recently some have the option of a selectable rear locker. Hope that helps
While ATRAC is no locker -- sounds like it would have been a big help in this instance. Your rear wheel had enough traction not to spin, so ATRAC would have put enough resistance on the other rear wheel to get you moving at least enough to get stuck in a few feet again...haha.
I think in your situation TRAC should have been on... it may have been enough to have helped.
Other than that, everything sounds like it worked as designed.
We have open differentials in the front and rear, you should try applying a little brake to generate some traction, which is what TRAC should have been doing for you if it was on.
Most 4 wheel drive trucks, are still just two wheel drive trucks.
Most 2 wheel drive cars, are just one wheel drive. hence the term, one wheel peel, and peg leg...
People spend big money on lockers as an aftermarket mod, really the only way to get true 4WD.
Are the 03-04 V6 the same?
When I lock the center I get all the tires turning.
I have had the 4runner literally jumping up and down as it slowly pulled itself forward in deep snow. Also up hill in soft dirt.
It will not get stuck in a cross-up diagonal tire traction loss. Like my old 1992 would.
Wheeling with BlackWorksInc one time he was stopped due to cross axle traction loss, he didn't have his center locked.
I did and didn't get stopped in the same spots.
OLD old thread...good info.
http://www.toyota-4runner.org/general-discussions/12-01-up-4wd-system-trac-vsc-torsen-t-3-a.html
