Shuddering When Gas Pedal is Pressed
CowboyBob
My 2000 2 wheel drive 4runner just started shuddering with a low rumble today. It starts at about 20MPH and usually stops around 50MPH. The 4runner shakes with a low rumble (like I'm driving on the rumble strips on the shoulder of the road). As soon as I take my foot off the gas it stops. Then as soon as I give it the any gas the shuddering starts again. This only happens when my foot is on the gas.
If I coast, it stops and shifting into neutral it stops. This is likely not an engine miss or wheel balance issue. Anyone have any idea what this could be?
Thanks,
Bob
You were right. It was the ball joints. No visible damage but when I remove the drive shaft, both of them were stiff and dragging.
Thanks,
Bob
I believe you mean u- joints, but you may want to check the LBJ,s also ( lower ball joints ) as that can be a real problem.
Thanks,
Bob
If you still have a vibration after the u-joints are replaced, you'll need to replace the whole driveshaft. The 2WD shaft has a rubber coupler/joint that wears with time and causes vibrations in the 60-70mph range.
-Charlie
2001ATL
