Side mirror swap to add turn signal and puddle lamp
Das Capitolin
I recently replaced my 2005 4Runner SR5 with a 2019 SR5. While I would have liked a SR5 Premium or TRD Pro, inventory is incredibly scarce during these strange times. At any rate, I got a great deal, but still would have liked side mirror turn indicators and puddle lamps. Unfortunately, these are not available on the SR5 or TRD Off Road.
Visiting eBay, I found these: Fits Toyota 4Runner 14-16 Set of Side Power Mirrors Heated Signal Puddle Lamp | eBay
They claim 2014-2016 fit, but I suspect they also fit 2017-2020. (?)
Aside from reusing my existing painted mirror shells, will these plug into a connection somewhere inside the door? Any experienced advice is appreciated.
Correct me if I'm wrong, premium models are wired for turn signals which the non-premium models are not. So these would not work.
Like gct4r said, your truck may not be wired for the puddles and turn signals.
For the mirror turn signals just wire it from the fender turn signal lights. As for the puddle, wire it from your dome lights.
I’ve read how Tacoma guys are doing the same mod and saw how the did the proper wires in the kick panel. Perhaps 4runner is the same.
I have a limited and my puddle lights turn on when I’m like 3-4 feet away or unlock the doors.
I have successfully upgraded my 2014-2020 Toyota 4Runner SR-5 to use TRD Pro mirrors with turn signals and puddle lamp.
This project would not have been possible without the retrofit wiring harness and detailed instructions provided by Tanner, aka Old Red. With his kit, you can upgrade the standard heated mirrors on a 2014-2020 Toyota 4Runner SR-5 to also include the side mirror turn signal and puddle lamp found TRD Pro mirrors. In upgrading my 2019 SR-5, I used aftermarket TRD Pro mirrors with the aftermarket sequential LED turn signals. I've posted the finished results on YouTube. Total project cost was $270 for all three products.
If you would like more information on the retrofit wiring harness, which was made using OEM Toyota components, visit Old Red's Instagram page.
Did you use the aftermarket mirrors from your first post? If so, how is the fit and quality of the mirrors? Thanks!
Yes, I used those aftermarket mirrors purchased off of eBay. They are okay, but fully aftermarket and not an OEM clone. They're still heated, although I have not yet tested that this works, and add signals and puddle lamps. Neither the signals nor the puddle lamps are OEM design, so those components are not interchangeable with OEM. In the end, they work, but they're not quite as durable (wall thickness is about 2mm vs 3-4mm for OEM). The painted shell was interchangeable.
Overall, they are not quite as well made as the OEM component, but you get what you pay for.
Thanks for the detailed info!
2010-13 side mirrors
Shout out to Old Red for all his awesome help ! We discussed getting the 10'-13' yr mirrors as they have better/larger mirror . found some on ebay & same plug & a bigger turn signal light very happy with so far ! Cheaper than buying oem new wow $$$$:hatsoff:
I have a '21 TRD Pro which has heated mirrors but no turn signal or puddle lamps. I am assuming that it is not pre-wired but does anyone know for sure?
It is not prewired in door harness, so you need aftermarket retrofit door harness from Old Red. Not to mention you need new mirror assemblies with signal and puddle lights.
Hey was planning on doing this mod, but couldn’t find Old Red’s aftermarket retrofit door harness? Or the installation video?
Can anyone help me out?
Your best best is to keep on eye on his Instagram, or check the other 4Runner forum. He's apart of that one and I would not expect to see him pop up on this one ever again
Mind if I ask why that is?
Simply put, I didn't like watching my time, energy, and effort that I put into my projects get deleted by a mod, to then have my harness designs (IP) ripped off by a certified scam artist that they brought onto this site. I freely gave info and was screwed over for it.
Read about it here:TRD Pro Side Mirror Swap/Upgrade
You might get a good laugh out of it.
Plus, the other site is far better, less adds, better UI. If you have questions, find me over there. Same username.
I find it odd to know Toyota built two sets of wiring harnesses for the same mirror. That's time, money, energy into two things. Doesn't sound like Toyota. Logically 1 wiring harness and either it has a receptacle, or it doesn't is far more efficient and far less chance for assembly error than two harnesses. Jeep does a one harness thing for the rear end. Sub woofer or not, convertible (wiper motor/wash) still get the same assembly. Makes it easy to add a hard top or for an aftermarket amp/sub with the 130 sound system.
I’m new to this topic and after reading everything and getting caught up I have come to learn Old Red is a legend, thanks for all the effort you put into the 4Runner community. I sent you a follow request on Instagram yesterday. Hoping you accept so I can shoot you a message about the harness :)
May I ask why you don't miss the puddle lights? I have an SR5 and would love to add the turn indicators side mirrors. I'm indifferent about the puddle lights but since the mirror will have the housing for them I might as well add them as well. Were the puddle lights annoying in any way?
i just smashed my driver side mirror on a 2012 SR5. Does anyone know if I can use the 2014-current side view mirrors with signal and puddle lights using this mod? I would love to bring my ride into something a little more this era. Thanks!!
