5th gear is overdrive. If you manually shift it over into 4th, you are effectively turning off OD. On cars that have the OD button, when you press it, it simply doesn't allow the vehicle to shift into the top gear which is 5th gear in your T4R.pduutkedu said:Yes, if I shift it left to 4, the rpm will jump higher.
