sirius in 07 usinf Toy-SC1
30/30
I installed the toy-sc1 in my truck. Dash off... wires in an the satellite works. There are three connectors on the back of the radio plus two antenna jacks. I removed the second from the right (looking at the front of tha unit) connector and plugged in the sirus satellite connector, and everything works, but I think I am plugged the amplifier.
I have tried doing a search in this form to find the proper information. Not getting the proper syntax for the appropriate information to come up. I have no support from clutchfield or other parties, because I bought this on eBay.
I went back 29 pages in this form, and now cross eyed.
I also read that there might be an interface under the passenger seat. Is this correct?
Do I need another part or pigtail to jack both connectors into the one hole.
In short, I need a wiring diagram.
Any help would be greatly appreciated.
30/30
The reason I thought I un..jacked the amp is the volume level dropped using the sirius satellite , it was low. Doing more search on the Internet. I came across this.
Plug the numbers in and the volume went up!
Here is the technical bulletin for the TOY-SC1 and HON-SC1
I'm just going to just put it down word for word.
Technical Bulletin: Setting Audio Levels
There is a built-in software setting for audio levels on these two interface modules that allows the installer or end user to match the level correctly for a particular vehicle. In some Toyota/Lexus/Scion vehicles, you may need to enter the toggle code to raise the level to HIGH so satellite radio level matches FM/CD levels.
1. Turn stock audio system on, switch to SAT operation.
2. Rapidly enter on the stock radio preset buttons the following code: "162534".
3. The audio level will toggle to the new setting, which you will hear immediately if the code is entered correctly and quickly enough.
4. If no audible change, enter the code again.
5. Check the audio level on similar channel from Sirius vs. FM, then try CD.
The default settings on the interfaces as shipped are as follows:
TOYSC1: default setting = LOW
HONSC1: default setting = HIGH
This worked great!(This is a cut-and-paste from somebody else's work). Hopefully it's useful to other people out there.
Getting back to my original question, what is the second connector .... plug jack used for . And why is everything seeming to work great. After unplugging it?
30/30
PS, if I'm on the dark side that's okay to!
