Skid plate bolts.
Okay a few years ago I had a mechanic install shrockworks front and rear bumpers on my 2015 trail edition. At the time I did not know many off road equipment retailers and the mechanic removed the factory skidplate and the bolts. Now I have procured a factory skidplate assembly but no bolts. What types of bolts should I get? Yes I was a moron but I have learned my lesson and I know of reputable shops in the area who I now trust but they all say $170.00 for the bolts wayyy to much.
You can try to re-use the existing bolts . For my TRD pro plate, I used two they came with it (front ones) and the two rears which was already on the truck. The original bolts connect to the radiator support brackets.
For non-kdss which seems like it should be the same the stock pan is held on with 4 8x20mm with attached washers. - looks like the parts listed above for 9008011373 - 1.29$ US
Front plastic has 2 6mm bolts + push pin
4 10x25mm bolts are the ones the TRD plate replaces - might not need those if they stayed in.
8 and 10mm look to be 1.25mm pitch
s!AogVU9yTt65ChvdiMmcz5BnTZlE4tg
Bunkstaff
