Skid Plate Recessed Bolt Issue
TX4Running
Member
I bought my original 2001 SR5 4WD back from the guy I had sold it to 7 years ago. Trying to drop the skid plate and the final 12 mm recessed bolt is starting to strip. I've sprayed it with PB Blaster. Any other suggestions?
I'm trying to change the oil and I know it's possible to do it without dropping it, but eventually it has to come down anyways. Thanks.
The bolt head is stripping. Not quite done but my 12 mm socket won't grab it. I ordered a 12 mm bolt extractor socket.
If you're trying to finish today you should be able to pick them up at any Lowes/Home Depot/etc, if you're talking about these suckers. I believe some auto parts stores even carry them, think I saw some in o'reillys. They're a life saver for sure
Yes sir. Ordered a 12 mm of those. Hope it does the trick. Fortunately, I can let the truck sit in my garage for a few days. Will hit it with PB Blaster each day and when the bolt extractor arrives on Saturday, I will try to get it out. Thanks.
Don’t underestimate the power of vise grips if the socket doesn’t work. I’d get a screwdriver in there to pry like someone said to help it and get the vise grips as tight as possible and she should come on out. Good luck, ain’t nothing more aggravating than one stinking bolt taking up all your time. Those skid plate bolts drive me insane. I’ve had my battles with them for sure.
After I typed this I saw you said “recessed”
My bad, vise grips ain’t gonna work there. Fingers crossed for the socket!
No problem. Anyone know part numbers to replace the skid plate bolts? Or size to buy some new ones? Thanks.
These look like it to me.
GENUINE TOYOTA UNDER COVER SPLASH SHIELD SKID PLATE BOLT 90080-11373 | eBay
Was trying to find the skid plate/bolts on the OEM parts diagram but still searching.
Finally found the skid plate in the diagram but it doesn't show the bolts, haha. Radiator Support for 2001 Toyota 4Runner | Camelback Toyota Parts
I have a strong feeling those bolts in the ebay auction are it.
P/N 90080-11373
You could just go to your local hardware store and take a good bolt and match it up. I'd replace them all and put anti-seize on them when you install them. They either have to be 8 or 10mm thread bolts.
I believe the skid plate bolts are M8-1.25 x 25mm flange bolts. You can get them in stainless steel. And as [MENTION=170353]Vansnxtweek[/MENTION] said, coat them with some anti-seize.
Also, always use 6-point sockets when working on a vehicle... Though likely the bolt was damaged before you got to it.
-Charlie
Yep - I upgrade any fastener I can with a higher grade/stronger material. There are lotsa online bolt distros with every damn thing you can imagine (if your local HW store or big box doesn't have it). My last order came from the boltdepot.com because high-grade metric bolts and nuts in a 1.25 TP aren't always easy to find on the fly.
Also, it's a good idea to hit a pick-n-pull for a vast assortment of Japanese fasteners for your Magic Bucket. You do have a Magic Bucket,.......right? LOL
For those that stumble on this tread and want oem, can confirm original part number 90119-08A33, replaced by 90080-11373
along with a "magic bucket" I keep an old bmw wire harness around....gets me lots more color choices on wires if ever needed....someday I will pull a 4 runner harness
I was at a friends house when his magic bucket busted open. Then it was a magic 1/4 of the garage.
-Charlie
Tie some strings to a 3 arm oil wrench, because you know you are going to drop it. Turn the wheel all the way to the left, pop out that mud guard, use a combination of extensions... reach under there with the oil wrench, then insert the extension while holding the oil wrench on the filter. You can access the drain plug without pulling the skids. So unless you really really love pulling the skid plates... Try this out. By "oil wrench" I am referring to this design, but I have not used this one in particular: Amazon.com: Innovant Adjustable 3 Jaw Oil Filter Wrench Tool Best for Removing Motorcycles Cars Trucks & Heavy Duty Oil Filters Fits Diameters 2 1/8-4 1/2 Inches Fits ⅜ and 1/2 inch Drive: Home Improvement
