Sky T case brake
I have the Sky T case brake and am trying to install.
I have read the instructions and have tried to install once, but the caliper was coming into contact with the rotor.....the contact was on the side facing the rear of the vehicle.
Now, when I bought the 4runner, the previous owner had already installed the rotor but not the caliper/caliper bracket. So when I began to install the caliper and bracket I noticed the interfereance.
Does anyone that is running this brake have any input? Is it possible to put the rotor on wrong? It appears by looking at my T case and rotor and looking at the pics online, it seems that the rotor can only go one one way.
Basically my problem is that the rotor is not centered in the caliper when installed.
OK, so I checked to make sure that the rotor was installed properly, and I think it is.
So I installed the caliper and caliper bracket, and when I tighten the bracket to the Tcase the caliper locks the rotor into place and the truck won't move. Its a tight fit anyway, and I'm wondering if there is some adjustment? I haven't installed the pivot arm or attached the brake cable to anything.
Here, you can see where the rotor is contacting the caliper, and it is locked in place.
This is before installation. Look correct?
