Slight jerk
Just changed all major fluid. Transmission, rear diff, engine oil. My question is, is it normal for the car to have a slight jerk while coming to a complete stop? Thank you
No, you might want to describe the symptoms better. Is the jerk under breaking conditions or when coasting to a stop?
I have the same problem. My mechanic said it was from the rear axle seals leaking onto the brake drums basically lubing them in certain spots. This means that when stopping the rear brakes slip then grab suddenly. Sometimes even locking the rear tires.
Vague description which is stating the obvious... Like others said the driveshaft can cause a slight jerk... If it's a side to side pull I'd closely inspect your front control arm bushings
leolediola
