slip yoke/driveshaft, interchangeable?
SDHNTR
I damaged my prop shaft removing a u joint. Found a used slip yoke on Ebay. Can I just slide this one into my existing driveshaft? Or is that a bad idea?
U really think just the yoke would make the whole thing need balancing?
It's just the front flange that I damaged. Should I just pull the flange off the new part and install it on my existing driveshaft with a new U joint?
Just make sure you install it so the yokes on each and are in the same plane, or you will have vibrations.
