Slow tire leak?
Jester4kicks
Need some advice on my girlfriend's car troubles. She's got a sedan with two tires that can't seem to stay inflated. They were filled to ~35 psi just a coupe weeks ago, and one of them is down to almost 15 psi, and the other is around 25.
She's taken them back to Big-O tires twice for this issue, but both times they just tell her there's no leak and send her on her way.
Is there some way a tire can leak air that a tire shop would normally find? What can she do?
Have you tried the soapy water, look for bubbles trick? Be very patient. Pull a tire off the car for best access, air it up, check at the valve stem too. Sometimes if the rim is too corroded a tire won't seat properly and that can leak too. Otherwise wow, those are some porous tires!
If there's no sensors to muck up, you could try hitting them with FixaFlat.
Tire Leak
Why not take it to another tire shop (not Big O) and have them put it in a water submersion tank. That will catch most leaks.
Yeah, unfortunately there are sensors, so I guess I'll just have to get the soapy water out and find it myself. I'll let everyone know how it goes.
Thanks for the responses!
