sluggercz's '05 Build Thread
sluggercz
How she look's now:
I'll try and keep this thread up to date as well as document each modification with pictures + a tutorial.
[Updated to include tools and parts used for each modification]
4Runner purchased 14th June, 2013:
1st modification, Plasti-dip'd Wheels:
  1. Tools: Jack + stands, 21mm Socket wrench for lugs, torque wrench (should go to at least 90ft-lb)
    Parts: Plasti-dip Spray(can be found at Lowe's, Home Depot, etc.), Index Cards and painter's tape.
  2. Jack one side up.
  3. Remove wheels and place index carts to prevent overspray, cover lugnuts with painters tape.
  4. (Not pictured) Spray light first coat, wait 30 min. Spray 4 more coats per wheel, waiting ~30 min. between each coat. Once done spraying last coat, immediately remove index cards and lug nuts and allow final coat to dry for ~40 minutes. Reattach wheels + move on to the other side.
  5. All done.
  6. Used about 2 cans of Plasti-dip for all 4 wheels.
2nd modification, Plasti-dip'd Grill:
  1. Tools: 10mm Socket wrench
    Parts: Plasti-dip spray, less than 1 can is needed.
  2. Unbolt front grill, use a 10mm socket. Should be 8 grey nuts that connect grill to hood, and 2 black bolts that connect hood latch to grill.
  3. (Not pictured) Follow same technique as painting the wheels, start with a light coat, wait 30min, then add 3-5 more coats.
  4. Re-install grill.
3rd modification, Badge removal:
  1. Tools: Heat gun or blow-dryer, metal scraper or dental floss/fishing line.
    Parts: Goo-gone (or other adhesive remover)
  2. To remove the badges I used a B&D Heat gun (though I'm sure a blowdryer would work just as well) and the metal scraper supplied in the kit.
  3. Set the heat-gun around Low-Med heat (~200 degrees Fahrenheit) and held it about a foot away.
  4. Angle the scraper to as near parallel to the side panel as possible to prevent any scratching.
  5. Use an adhesive remover if needed to get rid of any remaining gunk.
4th modification, Interior LED Swap + Auto-on Maplights:
Tools: 10mm Socket wrench, thin flathead screwdriver, crimper + wire stripper.
Parts: 4th Gen interior LED kit, 18AWG wire, Red wire tap connector, Blue Female+Male insulated quick disconnects.
Followed t4rman's "How to" on toyota120 forums.
Wired maplights to ILE circuit so they turn on when doors open/car unlocked, and dim after ~15 seconds. Followed JA's write-up, skipped using a switch though.
  • Maplights:
  • Maplights + Driver side door light:
  • Passenger side door light:
  • Rear lights(secured LED boards with hot glue):
  • Cargo area light:
  • Full length shot:
  • Night shot:
Washed and waxed this morning:
7th Modification, Additional 12V socket(for GPS):
Tools:10mm socket wrench, wire stripper + crimper.
Parts:12V Aux Power Socket(can find these at AutoZone/O'Reilly/etc.), Red Wire Tap Connector (22-16AWG), Red + Black 18AWG wire, 2 Red female quick disconnect terminals.
  1. Remove lower panel dash panel and metal shield, each is secured by 2 10mm bolts:
  2. Remove rear center console to access the stock 12V power connector(has 2 wire's coming out: 1 red, 1 white with a black stripe):
  3. Use wire tap's to splice into the positive and negative wire's, then run cable behind the center console to area underneath the steering column:
  4. Crimp a female quick disconnect terminal onto the end of each wire. Then connect the positive to the center wing on the added socket, and the negative to the outermost wing:
  5. I ran the GPS cable behind the side stripping:
  6. Reattach center console, lower dash paneling. Turn car on and test to see if the new socket is powered:
    Success! Now I can use both my GPS and radar detector.
Bumper/headlights removal + Painting Headlight Housing Black
Tools: Oven, 10mm Socket, Painter's tape
Parts: Krylon Satin Black Spraypaint
Write-up:
Part 1: Removing bumper and headlight assembly
  1. Remove the radiator shield, secured by 8 clips.
  2. Disconnect fog light cables.
  3. Remove front bumper, 6 clips and 6 claws on top. 8 bolts underneath.
  4. Disconnect High, Low, and Side lights.
  5. Remove 2 top bolts, 1 inside bolt and 1 bolt on outside. Top and inside are grey, outside is black.
Part 2: Painting the headlight housings and projector shrouds
  1. Remove all screws and rubber grommets from back of the headlights:
  2. Bake headlights in oven at 200deg. Fahrenheit for ~15 minutes.
  3. Remove light assembly from oven and use a thin flathead screwdriver to assist in prying the lens from the light assembly.
  4. Store the lens in a dust free environment.
  5. Remove amber reflector and diffuser for side light.
  6. Prep light shroud by cleaning with alcohol and masking side light area.
  7. Paint by spraying around 2-4 light coats, waiting ~5minutes between coats. Should take an hour to dry.
Painting headlight housing & BiXenon Retrofit:
Tools: Oven, 10mm Socket, Proxxon Rotary Tool FBS 115/E, Painter's tape
Parts: FX-R III Retrofit Kit, Aluminum Tape, JB KwikWeld, JB SteelStik, Clear Waterproof Silicone Caulking, Krylon Satin Black Spraypaint
References:
  1. 2004 Toyota 4Runner HID retrofit
  2. Projector Retrofit - 2006 4Runner
  3. Rickashay's Projector Retrofit
Write-up:
(in progress - pictures to come)
Part 1: Painting the headlight housings and projector shrouds
  1. Remove headlights from the vehicle, may have to remove front bumper to make it easier.
  5. Unassemble the headlight.
Keep it coming! we could use a good retrofit write up
Bilstein 5100/OME 885,895 Install
Bilstein 5100's/ OME 885,895 Install:
(Write up in progress)
Before:
After:
For the most part followed Photog's Write Up: "OME Install, No spring compressor". However, I found the OME 885's to be a bit too stiff to install when combined with the Bilsteins and had to resort to using the AutoZone Strut Spring Compressor.
Tools: 14mm, 17mm, 19mm, 21mm socket wrenches, Jack + stands, spring compressor (rented from AutoZone), LiquidWrench, Red LocTite
Parts: Bilstein 5100 Adjustable Front Shocks, Rear Shocks. ARB OME 885(Front) + 895(rear) coils.
  • Exploded view of Suspension w/Torque values, click for a larger image size (should help with visualization):
  • Components:
  • Stock front height: approx. 33"
  • Stock rear height: approx. 35"
Write-up:
  1. Will start on the front. Loosen lug nuts on front wheels. Jack up the car and place jack stands underneath frame on both sides - may need to use 2"x4"x4" pieces of wood to have enough ground clearance- remove wheels:
  2. Remove front skid plate:
  3. Remove sway bar starting with unbolting the sway links then unbolting sway bar brackets:
    Sway bar link:
    Sway bar brackets:
  4. Place floor jack underneath LCA and jack up:
Done with the install, here are the numbers for the new ride height(pictures to follow):
Front Right - Ground to top of wheel well:
Stock: 33" Now: 39"
Rear Right - Ground to top of wheel well:
Stock: 35" Now: 38.5"
As you can see, I now have a slight bro-rake - but hopefully the front will settle a 1/2" or more over the next month or two. If the front coils don't settle I'll probably get some top mount spacers with extended studs for the rear, most likely a 1/2" set.
LED Footwell Lights
Going to tackle the LED footwell lights today.
I'm going to be using the STRIP_RL_12_W_6k LED panels from VLEDs.
Since I'm still waiting on the Cole Hersee switch I ordered, I will be wiring this into the ILE circuit (the same wire the maplight mod taps into) so the footwell lights come on when a door opens and so they automatically turn off as well.
I'm using J.A.'s 4Runner site as a reference, here's the link.
From J.A.'s site:
Negative terminal taps in here
Positive terminal taps in here
I'm using a small battery pack with alligator clips connected to test different placements for the footwell LEDs:
Done with the footwells!
They took longer than expected, mainly because I had to fabricate some angled T-mounts for the rear footwell areas; also, I had to deal with the flaps on the bottom back side of the Limited bucket seats - folded the bottom half of the flap back and up behind the top half.
I'll post some pictures soon, but for now I can tell you that it makes a load of difference at night - especially when you are stepping into/out of your newly lifted runner.
You've been busy! Looks great!
Thanks, I'm digging your Satoshi grille - I think that'll be next on my to-do list after I'm done with the headlights & footwells. Nice write up btw.
Sure thing. Halos finally came in this afternoon so I will hopefully be done with the retrofit tomorrow, and I'll try to get the write-up posted by the end of the day.
Looks great, just like new. Looks like you have been on a mod craze like I was during the winter.
Haha yeah I've been pretty busy, I wish I was doing all this modding in the winter, working in the garage in the middle of summer is no bueno.
good mods!..ur truck looks gr8.......
Thanks man.
Headlight Retrofit
The LED footwells took longer than expected so I was only able to start the headlight retrofit by removing the bumper and headlights. I was also able to route all the engine bay wiring and mount the main relay and both ballasts.
I'll use this post to document the retrofit, and keep the previous post as a guide to remove your front bumper and the headlights, as well as how to paint them black.
Stay posted...
<write-up in progress>
TRS FX-R Stage III kit:
*By this point you should have your headlights and bumper off your vehicle - if you still need help on how to do so click here.
Write-up:
<Pictures on the way>
  1. With all the previous parts removed (headlights, bumper, radiator shield) find a mounting point on each side for the ballast, keep in mind the D2S connectors can only reach about 8".
  2. After mounting your ballasts, find a location to mount your relay - I mounted mine inside the front bumper, right next to the ballast for the front left headlight.
  3. Run the wires from the relay- one lead with blue/black wiring and 9005 female connection should connect to the old low-beam connector, another with red wiring and in-line fuse should run to + terminal of the battery, and two cables (each with blue/black wiring and a 9005 female connector and negative lead terminal at the end) should run to the ballasts.
  4. Use zip-ties to secure wiring to the frame.
  5. Next we will move onto the time consuming step of mounting your projectors to the headlight reflectors and housing.
  6. You will want to start by completely disassembling your headlights and storing the screws, gaskets, and rubber grommets someplace (I used the boxes the FX-R projectors were shipped in).
  7. Once disassembled hold the projector in the reflector to get an idea of what size hole you should cut out. Use your rotary tool to make the hole (make sure you are wearing eye protection and have your mouth closed, cutting the reflectors sprays a lot of fine plastic dust into the air - some nasty stuff)
  8. If you need some help on fitting your projectors onto your reflectors consult this video and this article.
  9. With the projectors sitting in the newly cut holes try to align the bottom of the projector with the bottom of the reflector, you want those two lines to be parallel to ensure they are oriented rotationally correct.
  10. Using the #8-32 6" threaded rods with NyLock nuts on one end, thread 3 rods into the top two and bottom outermost holes of the projectors. Mark where they hit the reflector with a Sharpie and drill holes wide enough to just barely fit the rod.
  11. Ensure that the projector with the rods fits into the newly drilled holes and that it is still correctly rotationally aligned.
  12. Reattach the reflector to the housing and place the projector with the threaded rods back into the reflector. Mark where the threaded rods hit the housing with a sharpie, then drill some more holes.
  13. Take your time to make sure the projector is sitting correctly, making small adjustments to the holes you drilled. Once you are satisfied go ahead and completely dissamble the reflector from the housing.
  14. At this point I painted my reflectors, making sure to mask off the Hi-beam reflector and remove the 3 clips that the 2 housing alignment bolts, and 1 housing pivot ball sit in
  15. You can also paint your shrouds at this time if you so choose.
  16. Using your aluminum tape, seal up any holes in your projectors.
  17. If you purchased the XBaLED angel eyes, secure them in the shrouds using silicone cauking or other type of glue.
References:
  1. Video playlist on YouTube that includes all of the TRS's guides.
  2. Aiming Headlights
  3. Different projector mounting methods
  4. 2004 Toyota 4Runner HID retrofit
  5. Projector Retrofit - 2006 4Runner
  6. Rickashay's Projector Retrofit
From TheRetrofitSource:
Retrofitting Guides - Imgur
Santiago Canyon
Just got back from a ride through Santiago Canyon, headlights are mostly done, just need to finish sealing them up with some Butyl Rubber.
Pic's for your enjoyment(click on the pictures for full size):
Started off on Maple Springs road.
My brothers FX4 F150.
The dog loved the ride.
delislerebecca
