Small 4 Channel Amp that will fit in factory location???
Mitchc4216
I have a 2002 Limited Runner with brand new polk speakers and some type of aftermarket tweeters. They sound really good but i can tell they just arnt getting what they can from the factory amp. Im getting a new Headunit soon and i know the FACTORY amp is directly behind the stock headunit. My question to you guys is that, Where can i find a decent amp that outputs 4 channels very well and is small enough to fit in the factory location. It doesnt have to bolt to the existing bracket i just want it to fit behind the OEM headunit.
Mitch
This is probably the closest you will find. At least I have never seen a smaller 4 channel amp. I would recommend that you avoid putting any aftermarket amp behind the h/u though. They produce too much heat and under the driver's seat would be much better.
I would strongly suggest not putting an amp behind the head unit. It will get too hot, also how would you adjust the settings? That factory amp is about the size of your fist, I have never seen an amp that would fit in there without severe modification to the dash cavity.
