Small Footprint CB/HAM Radio Install
DaPersianRug
Background
I wanted a handheld radio but I wasn't committed enough for a permanent mount. I had seen a handful of radio installation tutorials but I'm not a huge fan of making mods to a car without being able to revert back to factory default/make it look like nothing was ever tampered with. Thus, I decided to do a small footprint radio install. I knew a few people ( [MENTION=102185]WODWorldWide[/MENTION] )were interested in a small footprint write-up so boom, here we go:
The Setup
Midland 75-822 40 Channel CB-Way Radio
41QrD9t8AyL._SX425_.jpg~original
Amazon.com: Midland 75-822 40 Channel CB-Way Radio: Electronics
Bracketron Mi-T Grip
package_1.jpg~original
Suction cup mount, min-max width 2-3.25"
http://www.amazon.com/Bracketron-Mi...90768773&sr=8-1&keywords=bracketron+mi-t+grip
Recommended Tools
1. Trim Removal Tool
I picked up the 2pc version of this this set from Autozone
~original
OEM/4 pcs. plastic scraper (25513) | Molding and Trim Remover Tool | AutoZone.com
2. Clothes Hanger
wire-hanger1.jpg~original
Routing Procedure
I'll speed through the easy stuff:
The Mount:
Routing Under the Hatch:
Taking it inside. (Use needle nose pliers to seal the grommet after taking the cable in, makes it a lot easier than just trying to smear it back in):
Now that you're inside the cabin, remove the seat belt cover above the right taillight. I just grabbed the sliver opening where the belt comes out of the panel and it popped right out.
Leg 1: Push your cable towards the right taillight but don't worry about trying to be precise with your cable direction- If you feed enough cable the wire will start to circle around itself and push outwards, then you'll be able to stick a coat hanger into the seat belt opening (with cover removed) and retrieve the cable. Name of the game here is just feed cable into the hatchback grommet and pretty soon you'll see it peak out at the seatbelt cover.
Leg 2: After you've pulled all the slack of your cable, pull off the taillight cover with the trim removal tool and just keep feeding it down the panel towards the cargo area, gravity makes this leg of the routing pretty easy.
Leg 3: Once you've gotten your cable to the taillight cover, use that coat hanger to route the cable under the speaker towards the bottom of the seat belt. If you have 3rd row seats like me, now will be a good time to pull the seats up so you can easily grab the cable before Leg 4.
Leg 4: This part is super easy, no need for the coat hanger, just grab the head of the cable from the end of Leg 3, pull all the slack, then walk over to the passenger door. Tuck the cable under the panel as far towards the front of the car as you can, then tug/shimmy the cable so it all disappears under the panel where the arrows are. Once that part disappears, you can tuck the cable under the panels below the 3rd row seats, then tug/shimmy some more to make sure the cable hugs the wall so it doesn't make it's way back out of the crevice.
Leg 5: There are two panel screws hidden under the caps outlined below. The covers have a small notch carved into them so they're easy to pop out with your trim removal tool. Pop those suckers out and use a 10mm socket wrench to remove that step panel. Once the step panel is out, tuck your trim removal tool under the carpet and floor panel that touches the door. Wiggle that around a bit and it'll pop out too. You'll see a bundle of OEM cables already routed through some brackets, just open those routing brackets and add your antenna cable to the collection.
Leg 6: Keep feeding the cable towards the front of the car. The picture below is the front passenger area- you can see my antenna cable on the left of the bundle under the cable brackets. Once you get to the leg area panel it gets super easy because you can actually stick your hand behind the leg panel and pull your cable up towards the glove box.
Leg 7: Remove the accessory cap to the left of the cigarette lighter and feed your antenna cable through it. In the picture below I have the cap pulled, but I'm planning on using a hobby knife to carve a little opening into the cap so you don't have that ugly empty rectangle.
I popped off the far left screw cap to give my radio cable some room to squeeze out of the glove box.
Finished Product:
I know I didn't take pictures of each step as I was working through it myself so I do apologize for that. I'm sure there are going to be things I can help clarify so feel free to ask any questions and I'll do my best to get everything squared away for anyone interested.
Interesting! Tell me about the radio mount - is that a suction mount? Who makes it? Where did you get it?
Thanks,
David
Thanks,
David
Good question! Forgot to include that in the original write up (added it just now).
It's a bracketron Mi-T Grip, I picked mine up from the local Radioshack on a whim. It's a suction mount that I have mounted on the center console door in the pictures above. It's a really solid mount, doesn't have any wiggle or shake in it at all, so that part is great.
If you can though, see if you can find a suction mount that can hold items with a width less than 2".
This mount can hold the Midland radio but you have to get it in there just right (ie. you have to spend 5-10sec to position it in the mount if you don't want it falling out while you ride.... such a hassle haha)
Thanks for the post! I just bought a 2014 and hate making "permanent" holes in a car. This looks great ... I think I'm going to use this as a guide for my install.
Is that "easy" antenna mount a magnet/suction/or tape mount? A link for that would be nice also. I already have that specific radio in an Amazon wish list, but I have been having fits looking for an antenna.
ETA: I think I see edge clamps now in the second picture, but would still like confirmation. Thanks.
I've been using the Midland CB for about 4 years now. I never permanently mounted it because I have frequently transferred it between vehicles. It has been a very dependable unit. Always run mine off a mag mount antenna.
I would like to second this request. I'm looking at installing a CB and am researching antenna mount options. I really like the look of yours and would like to know the particulars about it.
