Snorkel
Not really useful info there. Yes the mold is done, but who knows how long it will be until they finally get it into production :(
Will they send you a 1 off mold? Tell them they don't even need to sell you the entire kit.
ARB Parts + Airflow Fender/Windshield Tube = frankensnorkel
Set up a group buy, tell them you have immediate orders for X number of snorkels, and see if that lights a fire under their a$$. Money talks.
I sent him an email basically asking how many units they would need to sell in order to expedite production.
I will start by saying I am interested in a snorkel
1.DLAK
I think the metal Mantec and Southdown snorkles for Discovery trucks looked way way better than the safari ARB plastic snorkles for the same trucks.
Would have to get measurements of the A pillar of the 4r vs the other kits, but I don't see why something like this couldn't be adapted.
Defender Puma Snorkel Unfinished
Southdown Raised Air Intakes consist of Stainless Steel Pipe Workand Hardware, with Injection Moulded Ram Scoop and Wing Mouldings.
A Combination which gives Looks, Strength and Performance. Ram Effect Scoop for Roadwork, Negating any Drag of the Plumbing with a Rotatable Top for Off Road .
The flexible hose on these units run directly from the base of the stainless pipe to your Air Filter Assembly eliminates several joints on standard pipe work that can fail, just when you don't need them too!!
If the Intake Mouth on an Air Intake system becomes blocked by leaves or other matter, large vacuums are produced. The resulting effect on side wing mounted systems is that joints fail, especially on internal standard pipe work.
The internal mouldings in standard pipe work that these externally mounted systems join to simply clip together. Their rigidity is such that the joints cannot stand large vacuums and they collapse.
Another often ignored item is the dump valve, too many forget to remove it when preparing for Off Road. Although this valve may work well for standard systems in letting water out that has entered the side air intake, in a short time the rubber becomes hard and perished. In Deep Wading situations these tend to let the water in, not out!!
Therefore, if you get stuck mid-stream engine running, preparing the winch, time goes by, Ooops, Engines Stopped. Hydro-locked Engine ££££'s.
KEEP AWAY FROM THE WATER!!
Don't Get Caught Out! Use a Southdown Raised Air Intake!!
SHIPPING: The shipping calculator can work out costs for the UK and W Europe. If you do not see
a shipping cost in the last page of the Checkout, email us at [email protected]
for accurate rates.
The Defender Puma Snorkel kit comes complete with:
Unfinished stock Stainless Pipe,
Ram Scoop,
Wing Moulding,
Flexible Hose,
4" Rubber Adapter (for airfilter housing)
Fitting Kit and Template.
The only things that are not in the kit, are tools for the job and a suitable PU adhesive such as Tiger Seal
or Sicoflex available from most motor factors or car paint suppliers.
www.discovery2.co.uk / Disco 2 Southdown Snorkel
www.discovery2.co.uk /Raised Air Intake (snorkel)
Please add your name to the list if you are interested in purchasing a snorkel. We are trying to get an interest list together so that we can try to speed up the production process. Currently they have the mold for the 5th gen complete but have other priorities ahead of the 5th gen and do not have a final release date yet.
1. DLAK
2. iFlyUSCG
3. Bflan
4. TexasAg
5. harper7
6. MeBe4running
7. Adio3x
8. PraticalFJ
1. DLAK
2. iFlyUSCG
3. Bflan
4. TexasAg
5. harper7
6. MeBe4running
7. Adio3x
8. PraticalFJ
9. Darkandshiny
10. SeattleMike
11. Trail
1. DLAK
2. iFlyUSCG
3. Bflan
4. TexasAg
5. harper7
6. MeBe4running
7. Adio3x
8. PraticalFJ
9. Darkandshiny
10. SeattleMike
11. Trail
12. Crusader131
1. DLAK
2. iFlyUSCG
3. Bflan
4. TexasAg
5. harper7
6. MeBe4running
7. Adio3x
8. PraticalFJ
9. Darkandshiny
10. SeattleMike
11. Trail
12. Crusader131
13. FJCRUZR
14. Tlfow
DionicioLives
