Snowflake Symbol
HB 4X4 said:
Offroad there wasn't much difference other than the BFGs kicking up 10 times more debris.
Oh no, that just means that the BFG is actually clawing through dirt. Your Nittos is probably just spinning like glazed donuts! :D And in mud, this "characteristic" is good for self-cleaning. (Disclaimer: all all-terrains suck in mud.)
Can you air down Nttos? It doesn't have sidewall traction bars to help with traction when the sidewall is deflated (when you air down). And, NO, those cheesy "lightning bolt" imprints do NOT count! :D
HB 4X4 said:
So I was just curious. Does the Snowflake symbol on some tires actually help sales? I know the symbol is meaningless since all they have to do is pay for the rights to print the symbol. Some companies simply do not care about it, but does this have any real purpose other than a nice silver lining for marketing?
BFG AT KO for example, is alright in snow for the first few thousand miles, but after that it's like walking onto an ice rink with your bare feet. So what's the point in paying $$ for a symbol, when they could put that money in actually helping their design for better traction?
Has anyone had positive experiences with snow traction from a tire that has the snowflake symbol?
From Tire Rack:
NOTE: While most BFGoodrich All-Terrain T/A KO tires meet the industry's severe snow service requirements (and are branded with the mountain/snowflake symbol), selected tires do not. Tires not meeting the industry's severe snow service requirements are identified on the Sizes & Pricing page, as well as the Specs page with a "Not Rated For Severe Snow" notation to the immediate right of each applicable tire size.
From 4Crawler
Road Test Update:
Well its now been a few years since installing the tires. I find they work quite well off-road, the 10.50s air down much lower than the 9.50s, not sure if that's due to construction differences between the newer KO design or just the rim/tire width difference. The ATs do not work well in mud, I sort of knew that, but they work great in every other condition I've run them in.
Awesome in snow:
Some folks report problems with the AT/KOs in certain snow conditions where the snow is freezing and ices up the tread.
_______________________________
Josh,
Do you know if the tires you had experience with were severe service rated?
I have no facts, but I feel that the mtn/flake symbol is awarded primarily on the rubber compound. Sure, there is a test that states the tire must earn a traction rating of 110 vs a benchmark tire, but with new tire technology, it seems easier for an A/T to earn the cert. For example, the GY SA and GY Triple Tread are two very different tread designs, the latter not even worthy of a dirt road, but both have the severe weather rating. It boils down to the ability of the rubber to remain pliable at freezing temperatures.
For what the BFG KO brings to the table for on/off/snow performance, the tire is one of the best A/T's out there
A/T's that have this rating are certainly using it as a selling point, give the consumer a choice between tires, many will choose a "safer" tire. However, these tires do not compare to the snow performance of dedicated winter tires.
Blizzaks use a microcell compound, which exposes microscopic ridges to the snow surface, providing it with its superior traction. Toyo uses ground walnut shells :biggrin2:. Nokian uses a combination of proprietary rubber compound, siping and innovative studs to achieve their levels of safety. These tires truly deserve their own rating, so as to not confuse a consumer buying a set of snowflake AT's thinking they can hang with someone on a set of winter friction tires.
Re: Re: Snowflake Symbol
True. Remember, the snowflake symbol is the minimum standard for a true winter tire. Like my example above with COSC and mechanical watches, one watch may be more accurate than another watch even though both are certified by COSC.
Thus, for a AT tire to have the snowflake symbol, it is like icing on the cake. :)
Thai said:
Here is a link that i have ALREADY posted in the main thread about this topic...but here we go again.
Link: http://www.meadowcreektire.com/severeservic.html
"In the future, all Nokian Tyres will bear a snowflake-on-the-mountain symbol denoting that they are suitable for use in severe snow conditions."
So, apparently, Nokian is quite aware of the snowflake testing and its tires do meet the standard. (Yes, some of the older Nokian tires do not have the symbol but are still excellent...these tires were designed/manufactured BEFORE the snowflake symbol came about.)
So, again, this snowflake-on-the-mountain symbol is LEGIT and is RESPECTED by everyone around the world, including the major snow tire manufacturers.
And just for kicks, here is the info on Bridgestone Blizzaks: http://productcat.bridgestonetire.com/exports/pp_910153.pdf
Do you notice something on the sidewall?? Yes, it the snowflake symbol!! :)
I agree with you in the sense that the standard is a "real" standard with "real" meaning in terms of performance. My point was more about the business end of it and marketing. My point is/was that there are, in all likelihood, some tires out there that meet could/pass the test but may not be branded to avoiding overlap of product line.
With a little more siping perhaps the Revo could pass the test. Why would Bridgestone even try? Bridgestone devotees are happy to buy two sets of tires. If the Revo was certified it may cut into sales rather than improve sales. I am sure Revo sales would increase some small number. Blizzak sales would suffer. I don't know if I fully believe that argument I just made but I think a bunch white collar marketing guys could (perhaps reasonably) use that type of argument to choose to NOT certify.
GMC dealers are with Pontiac/Buick not Chevy for the obvious reason of product line overlap. Maybe that
Nittos just received the snowflake symbol recently and they are the same tire as I bought over 3 years ago so it is a bit of a marketing thing but it's nice to know that some tires have acheived certain standards to be recognized.
Does it make me feel better now that Nittos have it? No,not really since I had a few winters already on my set and have been quite happy.
Wow, Nittos has the snowflake? Cool. Do you know where i can get info on this?
flipmode said:
Just noticed, the REVOs are not snowflake rated but (at least according to Tirerack's survey) perform better in winter conditions than other tires that are snowflake rated.
Ooopss, missed this post. TireRack's consumer survey is based on people's views, usually comparing their brand new purchase with their old ragged tires. TR surveys are not reliable IMHO. The snowflake symbol is. It represents controlled testing standards on a tire...no consumer bias.
HB 4X4 said:
Believe what you want. I know that there is no force on this earth that will ever change your opinion about your beloved BFG's or the all mighty Snowflake. This is why I wanted your input. I was seeking the most radical believer. :D
That is simply not true. I recommend many other tires (Yokohamas, Michelins, Goodyears, Bridgestones, etc.)...it all depends on what the poster's situation is. You will never catch me recommending BFG AT KO to a highway-only driver. Nor will you catch me recommend any other BFG tire, besides M/T and AT KO. (Remember, i bought Firestone Destination M/T over BFG M/T recently...so, i am far from being a BFG fan.)
I believe that i am free of bias for the most part. I post what i have experienced and what unbias data points to. If you need proof of what i wrote, then feel free to ask me to back it up. If i have told you that i have experience with certain things, then just ask me to prove it. Simple. No trickery. No hiding things. Hey, and if i am wrong, then i will tell you.
You know...i simply cannot find any link/fact to this. I have searched Nitto homesite and got nothing.
RonM...are you sure???
Dune Grappler got it somehow... My guess is all the heat from the flame print on the sidewall just melts the snow!:lmao:
:cheers:
:cheers:
:D Hate to say it, but Nitto truck tires are kinda cheesy in design...more "rubber bling-bling" than most other tires!
But, Dune Grappler is NOT what RonM has. Did he just throw that in just to sidestep the issue?? :confused:
RonM, do you have anything to back up your claim?? I certainly hope so.
So, in conclusion, the snowflake symbol is legit and well-respected throughout the world. It is highly regarded among all tire manufacturers, including those that specializes in snow tires. This symbol, therefore, is NOT just a marketing tool. It represents a real standard for winter tires.
Once again, you do need to do your homework more on tires before jumping to conclusion and making wild speculation. Whether you need this symbol or not on your next tire is up to you and your needs. For me, i don't really need it, but it is icing on the cake for an otherwise good tire for my needs.
Good luck with your purchase.
I agree about the icing on the cake thing.
No offense to anyone that has them but I must admit that the Nitto Dune Grappler is a awful looking tire with those flames and all. I don't know maybe they work great , just not my style. Seems to be a show attraction. The others like the TG look great IMO.
You know what was weird when I was looking at those Nokian AT tires ( began with a V I think), the ones I looked at had no symbol on it which I found strange since I thought they were really into the severe weather thing.
How do they test these tires to see what qualifies to get the symbol and who actually makes that call if it does or does not "make the cut"
Link: http://www.tirerack.com/images/winter/TiresSuitableforSevereSnow.pdf
The Nokian tire mold may have been made BEFORE the symbol went into effect.
From another link:
"North American tire manufacturers and the Rubber Manufacturers Association (RMA) have established a voluntary, industry-wide definition for passenger and light truck tires intended for use in SEVERE SNOW CONDITIONS.
Tires must meet a performance-based criteria feature tread pattern, construction elements and materials which generally provide snow performance superior to that of tires bearing the RMA's current M&S Rating.
RMA Severe Snow Conditions-Rated.
This new standard is intended to complement the current M&S rating and make it easier for consumers to distinguish all-season M&S rated tires from those specifically designed for SEVERE SNOW CONDITIONS. Tires that meet this new standard will now carry both the M&S-rated marking and the accompanying mountain/snowflake pictograph shown to the right.
SAFETY NOTE: Tires with this new designation provide a higher level of snow and ice traction compared to M&S or unmarked tires. Therefore, they must be mounted only in sets of four (4). This is necessary to maintain the handling balance of the vehicle both in snow and ice conditions as well as on dry pavement."
Well Thai, everyone is entitled to their own opinions. On that note, I continue to respectively disagree. You're the only person I have talked to who took that view, which is why I wanted your input. The symbol may be recognized, but I still believe it to be misleading. Maybe it's just on the AT KO's, and all other tires with the symbol perform excellent, however, in this specific case, I believe it to be incorrect and nothing more than marketing. If they tested AT KO's after 5,000-10,000 miles on them, they would never pass. I believe a strong durable tire is the basis on which good traction comes from, so if the design is great, but quickly turns flawed, no thank you.
Icing on the cake maybe, but the cake is definitely not my flavor-I prefer consistency.
As always, thanks for getting the information out for us.
For every opinion like yours, i can find others who has the opposite. For example, member "p nut" found that the BFG was a lot better in snow than nittos. Who does one believe??
Opinions are like ass-holes...everyone has them. :D
However, the snowflake symbol represents a basic requirement for winter tires. That is all it is. It is NOT an opinion. It has nothing to do with my view.
It is actual test data by RMA. It represents UNBIAS data for which you can compare two similar class tires.
Maybe your experience is due to poor tire care on your part?? Who knows! The point is that the snowflake provides an UNBIAS basis to compare tires.
What view am i holding that is so singular?? My view is consistent with every tire manufacturer AND tire distributor. You make it seem like i am the only who thinks the snowflake symbol is legit.
As noted in the past 3 pages this thread, the snowflake symbol is widely recognized and respected by all who knows what crap he/she is talking about. Which part of this did you miss??
BTW, if "consistency" is what you want, then why are you in the market again???? :bash: Oh wait, you had a flat while off-roading, didn't you? And why was that?? Oh yeah, you couldn't air down because you were scared of Nitto's weak sidewall. Hmmmm...so, what did you come up with now?? Oh yeah, lets go out and buy Nittos again with the same freaking weak sidewall! Ok, go ahead and buy the Nittos...i won't laugh anymore! :D
Interesting opinion from a Nitto TerraGrappler owner...
_ACT3950.jpg~original
http://www.titantalk.com/forums/tit...toyo-pro-comp-mickey-thompson.html#post724706
Thai, you'll get a kick out of his conclusion.
I disagree, I hate the terra grapplers in snow. my revos are ten times better(granted they are oem size)
Every day in 4x4 on the roads in Alaska I am sliding all over the place. but hey, opinions are like ...
____________________________________
workingwheelswnc
