...for the first time on my 2013 4runner, thanks to [MENTION=65614]Antman[/MENTION]'s very helpful write up. FYI-It has been serviced by 3 different dealers since I've owned the car and now has 73k miles.
No surprise at all, but there are some issues.
Biggest issue, is that the filter housing plug is stuck on there. It may have been over tightened? But I don't see how it can be tighter than the cap itself since it only needs 18ft/lbs and the plug only 10ft/lbs? Have you guys ever experienced a seized up filter housing plug? I was going to try and carefully remove it but I was afraid I'd be stranded with a broken filter housing cap. So, I left it and decided to source a new cap/plug.
Other issues, are that a couple skid plate bolts are stripped. Not the actual bolt itself but threads that the bolt screws into. Actually, one bolt was replaced (different coating) because the threads were stripped. Seems like an easy fix...BUT how hard is it to remove a few simple bolts?? WTF? I already had one dealer strip my wheel lock key because he used a friggin impact gun to get the lugs off. He even tried to send me off with missing lugs even after I explained that I would be going on a 1000 mile roadtrip with a family of four in the car and fully loaded with luggage and gear.
Now before you flame, I usually do my own oil changes. I've done them all with my previous cars. I recently just got my garage cleaned out and the floors sealed. I finally have the room to do some minor maintenance. Oh yea, newborn babies will eat up your time too. Just too busy sometimes.
Now, I know I can't prove which dealership nor will they ever admit to it but what can I do about the seized up filter cap plug? They'll probably blame me for it since I was the last one to work on it. Can I warranty it? I checked online for a new cap/plug assembly and all sources seem to sell it with a new filter/o-rings and rings out to about 90 bucks.
thanks for letting me vent....
J
J
