SOLD: 2000 Toyota 4Runner Sport 4x4 - 5spd manual 202K miles in central CA
d_benet
SOLDHi all,
I will likely regret this, but I'm selling my 2000 Sport 4x4 with 5 spd manual. I'm the second owner since 2009 and current odometer reading is 202K miles. I have loved owning, working on (thanks to many on this forum) and adventuring in this vehicle. I kept a detailed maintenance log and all receipts /photos of work done are available upon request. Tons of upgrades and maintenance items including all of this in the last 20K miles:
180K - timing belt, water pump, crank/cam seals, idler bearings, thermostat, multi-rib belt, spark plugs/wires/coil packs, all gear oils changed, new Dueller AT tires (265/75/R16)
182K - 2" Bilstein lift (6112 coilover fronts and 5100 + OME 906 coils rear), new lower ball joints, inner/outer tie rod ends, poly end link, sway bar and steering rack bushings
183K - new OEM clutch, custom Satoshi style grill, mud flaps, lift gate struts, LED dome lights, etc
186K - Tundra brake upgrade (best thing ever done to the vehicle)
190K - powder coated skid/fuel tank plates, hitch receiver, undercarriage treatment, power steering filter and flush, new battery
193K - new throttle body and cable, IAC valve and MAF sensor
202K - new OEM driver seat cushion, replaced sunroof glass and windshield
There is some clear coat failure and exterior/paint issues and some minor undercarriage surface rust from living next to the ocean. Could probably use valve cover gaskets eventually but motor is in great shape and pulls strong. Interior is in excellent shape with everything in good working order; all buttons/electrical, heater, AC, sunroof, fog lights, Pioneer head unit with Kicker speakers and custom raise/lower switch for antenna mast, etc etc. Will swap back to the factory roof rack unless buyer wants to purchase the Yakima's currently on there.
I'm asking $11K on Craigslist, maybe lower for a good home with a forum member. Smogged and detailed today. Thanks for looking.
2000 Toyota 4Runner Sport 4x4 - rare 5spd manual - cars & trucks -...
