**SOLD** complete RS3000 Alarm with 2 remotes for 3rd Generation
Singtoe
SOLD already:
This was a dealer installed VIP RS3000 Alarm. This came out of a 96 4Runner. It includes the RS3000 Alarm computer, the complete wire harness, the piezzo beeper, the glass break detector, the warning light and 2 key fob remotes. One on the key fobs is missing a battery and a small screw. I am asking $120 shipped. I will post installation instructions on to this thread. There are 5 wires to splice and 4 plugs that tie this into factory system
Alarm1.jpg~original
Alarm4.jpg~original
Alarm3.jpg~original
Alarm2.jpg~original
Alarm5.jpg~original
Here is a link to the owners manual.
Here are quick instructions. All the wires are the same colors as the wires the splice or plug into. the alarm is mounted under the drivers seat The Warning light and Mic was in the center console but can be put in the rectangle hole near the Dimmer switch.
Tools needed for the installation - 12mm tool to remove the driver-seat, 10mm tool to remove lower dash board panel, Phillips screwdriver to remove drivers threshold plate and the plastic cover under the steering column. Pliers the lock the splices in place.
These two splices are in the lower kick panel on the drivers side
Alarm6.jpg~original
Alarm7.jpg~original
The plug is located at the top of the fuse box
Alarm8.jpg~original
This splice and plug is located at the ignition switch.
Alarm10.jpg~original
The last two splices are located under the steering column.
Alarm9.jpg~original
Were you using this unit in your own 4Runner ? Everything works fine and no issues at all ? Why are you selling it , out of curiosity ?
Thx
Thx
I am breaking down a 96 SR5 4Runner that i bought. The remote worked the door locks but i did not see if the glass break or the motion sensor was working, but they look to be in great shape. The one remote is missing a screw and a battery.
