Some one please help!
zack97ang
I need information and i suck at using a computer, and this forum thing is driving me wild, i do know users encourage the search function, and trust me ive tried! i just need someone who knows what there talking about....im trying to put steel wheels on my 1997 4runner, im having trouble because im told i need to use wheel spacers with some of the applications! i need to figure this out quickly becuse my 4runner is lifted 5'' with 31's on it, i need bigger tires ASAP and new wheels, so someone, please help me figure out how to put steel wheels on my truck, ones that will fit! thanks!
You have quite a few answers you are looking for with information you haven't provided.
Instead of searching on here, search google. This search sucks a$$
copy and paste: site:toyota-4runner.org
This searches this forum. Any words after that will be searched. Just make sure it's under the 3rd gen forum so it's model specific.
Ie, type 35's, or back spacing, etc.
Ask knowledgeable tire shop too.
My info is very basic and should be confirmed, but stock back spacer is I believe around 4.85"??. Many like to space that out to clear limited flares. 33's should fit, albeit close with stock wheels to rubbing upper control arms. 35's I believe rub and require adjustment in BS and trimming/body lifts.
Just use my search method above to find info. ie: site:toyota-4runner.org 35 tires or 33, or back spacing, or whatever.
thank you very much guys, a appreiciate you getting back to me. Im looking to run a 15'' rim. i kind of need to be told the backspacing haha i want to run a 33x10.5r15 and just want to a steel wheel that fits. Thanks again
To search just the 3rd gen forum, use site:www.toyota-4runner.org/3rd-gen-t4rs/
OP, you've got some research to do. Do you know what backspacing is? You need to know the backspace on your current rims and the backspace on the rims you want. If the new rims have more backspace than your current rims, the difference between them is the size of spacer you need to use.
If you don't have a particular rim in mind yet, then it's easy. Measure the backspace on your current rims, and buy new rims with the same backspace.
15's and 33/35's NOO get 16's and do the tundra BRAKE UPGRADE. Safer and better stopping lower, especially with huge tires
thanks guys! does anyone run or know of anyone running a steel wheel on thier 4runner? what brand is good, im only trying to fit 33x10.5r15. thanks again!
tuṣṭāva
