Sonoran Steel lift install
If you want an example of a customer that needed the Radflo 2.5's and reservoirs. This is it. It's a 3rd gen but could have just as easily been a 5th gen. In fact our 3rd gen kit uses 5th gen rear shocks, so it was 1/2 a 5th gen kit.
https://www.facebook.com/permalink....674104210&id=249230485140707&substory_index=0
So you don’t feel good the Bilstien 6112/5160 is a worthwhile upgrade over your set up? Would you still recommend your kit if I wanted to switch out the rear spring and only run a 1” lift spring? I want to end up with a 2/1 lift. I really dislike the look of a 2” rear lift on 265’s.
We wont touch the 6112 my personal feeling is it was one of the biggest failures Bilstein has ever put out and now they have a fancy full blown coil over like everyone else. They must have though so too.
The 5160 is also not something we will touch. A reservoir that small is not going to do anything. You need a full size reservoir like all of the big manufactures use.
I can get you a 2" front lift but we have nothing to gain a 1" rear lift. The front coil overs are not cheap as the coils are around $260 each retail.
I would consider the Radlo units as your almost there price wise. But the Bilstein/TRD setup is much simpler and maintenance free.
I like the idea of the TRD coil. I was think ether a Dobinson or Eibach 1" coil or maybe just a spacer. I guess I'm shying away from a 2.5" for now. Seams like more money then I want to get into as of now.
Ok I can get you just the front set at 2" if you want.
lindwlson982
