Southern Style OffRoad Group Buy - 5th Gen 4Runner Rear Bumper
Status
Not open for further replies.
I'll have to back out of this last minute.
I have financial issues that came up. Will have to buy it down the road.
I apologize
Yes! So in.
I want:
-Bumper,
- tire swing arm w/ highlift mount
- dual jerry can arm
-side ladder
-black powdercoat,
-high clearance hitch
- camera relocation kit.
- side of fries
How's this going to work for ordering?
Once we get to the number I am told he will add the product to the site with a coupon code that you all will input giving you the 15% off I will post here what that coupon code is as soon as I have it
Hey [MENTION=123371]fargo4x4[/MENTION], when you speak about the drop hitch, how low does it actually go? From the pictures of your rig, it seems the high clearance that requires some rear frame mods makes the bumper relatively flush, thus providing a clear departure angle. The benefit for me is not needing to do any cutting of the frame, but would the drop hitch significantly or slightly reduce my clearance angle beyond what the stock SR5 bumper is rated for. Thank you!
The drop down hitch will basically be the lowest point on your rear end which for the most part is how it is on your stock bumper. Kevin would have to confirm this but im also of the belief that the integrated hitch is a much stronger tow point then a bolt on drop down hitch receiver is... Most of us arent towing anything insane since these vehicles are not meant for heavy towing but if anyone has aspirations of maybe action trailers or pulling a camper I think I would definitely go with the integrated hitch like we have.
I apologize
Sorry to hear =/
No reverse light cut outs?
As of right now no but we have our reverse lights on the roof rack anyway which we find to be a bit more practical.
So here are some shots with the hatch open, keep in mind ours is the frankenstein prototype but essentially this is what we came up with. Which you all will receive something similar as well.. The step plate will bolt on to the same holes the old bumper did and rest on top of the SSOffroad bumper or can be fastened to it. Ours doesnt quite fit properly but it does the job. Yalls will look similar but fit better.
20160301_114333_zpsobusbrzl.jpg~original
20160301_114442_zps4tqpszqm.jpg~original
20160301_114432_zpsojwtsxip.jpg~original
http://i1077.photobucket.com/albums/w477/ruggedpix/fargo4x4/20160301_114451_zpsrxzjknhq.jpg
This is enough motivation for me to send in my tax docs to my cpa. If I'm getting a refund, I'm in on this bumper. Unfortunately I won't know till next week probably
I like the high-clearance hitch but am a bit intimidated by the idea of cutting my frame. I'll likely be installing the bumper myself. Will cutting it make it more susceptible to rust and/or breaking? I ask because I'm ignorant on such things.
I don't plan on doing any crazy approach and departure angles. Will the drop hitch really make that much difference? I was able to do pretty much what I want with the stock bumper and hitch, only rubbed slightly at the worst of what I was driving.
Im in!
Rear Bumper, Tire Swing Arm with highlift mount, Dual Jerry Can Holder Swing Arm, Side Ladder, Black Powder Coat, Drop Down Hitch Option, Stock Rearview Camera Relocation Mount, Combining shipping with [MENTION=128572]TRDZEB[/MENTION] & [MENTION=103959]cyclist[/MENTION].
[MENTION=123371]fargo4x4[/MENTION] thank you for the reply! Just as a final question having to do with install. The bumper is heavy, noted; however do the pieces ship all connected with the assumption we mount the bumper...or does it ship in "incremental" pieces (all at once of course) and we can install it ourselves without need of jacks or "pro" hydraulic lifts or equipment. Pretty much since I'm babbling, summing it up to: can two people of relative strength install the bumper? Thanks!
3 more to go before orders get placed through SSO. :bounce:
[MENTION=123371]fargo4x4[/MENTION]- Thanks for posting the pics inside the hatch. I think it looks great.
[MENTION=119136]nmhyoti[/MENTION] install will be very similar to any steel bumper install. I'm sure 2 people can easily complete this install. I'm assuming the bumper will be shipped in pieces(accessories detached) on a single pallet as opposed to compeltely built.
[MENTION=126331]Eric0321[/MENTION]- The integrated hitch is for those that want the most clearance possible. If you feel you don't need that, go with the drop down hitch. Cutting the frame won't cause rusting as long as you paint over what you cut. Just make sure there isn't any raw exposed metal.
I am going to look into fitting a small led pod to the left and right of each shackle mount facing directly backwards.
Also the bolt on hitch will be designed so that it can be taken off for the same departure angle that the integrated hitch does. It will only be rated for 3500lbs.The fully integrated hitch is proven to 5k lbs.
Edit. I think I read this wrong. Let me rephrase. High hitch that requires cutting is good for 5k, drop down hitch option that doesn't require cutting is good for 3500#. Did I get it right?
Can the OEM hitch be used at the same time with the bumper, so the full 5k can be achieved? I'm thinking I may pull a 4500# camper in the future.
Also, did you figure out the 2nd receiver option I emailed about? Thank you
Please put me down for bumper, tire swing out, drop down hitch, and the free camera relocation kit. Before ordering the Jerry Can Holster, does the bumper already have in place the connections for the future order of an extra swingout (whether it be the actual jerry can or ladder)? I'm sure it's been asked before but the parts are modular and if we don't order the left side swingout accessories, we can still order it down the road and plug and play, right? I apologize for the many questions!!
This answered my question. You can keep my order the same @RiDE
[MENTION=103959]cyclist[/MENTION] Yes you got that right, that is what [MENTION=110183]SouthernSS[/MENTION] said. I doubt the OEM hitch is usuable with this bumper. If you plan on pulling 4500lbs it sounds like you need the high clearance hitch.
This sounds awesome! I definitely want this in my bumper. Any idea what type of light you're going to use as a template for the cutout? Maybe a Rigid SRM or SRQ?
If you look at our original post i think some shots are there as well as our instagram, we installed it in our driveway and did all the frame cutting in our driveway as well lol its a little tricky but with 2 people you can pull it off... the frame cutting is the hardest part mainly cuz we just picked up the bare minimum tools from harbor freight lol but its a fun project =)
It will ship all as one you will have to install the swing arms after you install the bumper of course
Put me down as a definite, PENDING 2nd Receiver question.
Rear Bumper
**2nd 2" Receiver attached to tire swing arm for bike rack**
w/Tire Swing Arm
w/Dual Jerry Can Holder Swing Arm
w/Side Ladder
Black Powder Coat
High Clearance Hitch #5000
15% off :)
Combine Shipping with [MENTION=128572]TRDZEB[/MENTION] and [MENTION=137928]SlateFalls[/MENTION] -- Will be shipping to [MENTION=103959]cyclist[/MENTION] Commercial address with loading dock.
If we end up not being able to do the 2nd receiver option, I'll have to order it bare metal and modify it. Hauling bikes with my 1UPUSA rack is an everyday thing. Need to be able to open hatch without removing bike rack. I can't be the only one.
Current GB list as of 3/1/16 4:46pm pacific:
1. [MENTION=78318]RiDE[/MENTION] - Bumper, tire swing arm w/ highlift mount, dual jerry can arm, side ladder, black powdercoat, high clearance hitch, camera relocation kit.
2. [MENTION=128572]TRDZEB[/MENTION] - Bumper, tire swing arm w/ highlift mount, dual jerry can arm, side ladder, black powdercoat, drop down hitch, camera relocation kit.
3. [MENTION=133520]cummins67racing[/MENTION] - Bumper, tire swing arm w/ highlift mount, side ladder, high clearance hitch, camera relocation kit.
4. [MENTION=93405]Snow-Jet-MK5[/MENTION] - Bumper, tire swing arm w/ highlift mount, bare metal, high clearance hitch, camera relocation kit
5. [MENTION=126331]Eric0321[/MENTION] - Bumper, tire swing arm w/ highlift mount, dual jerry can arm, side ladder, black powdercoat, drop down hitch, camera relocation kit.
6. [MENTION=136889]E2Adventures[/MENTION] - Bumper, tire swing arm w/ highlift mount, side ladder, black powdercoat, high clearance hitch, camera relocation kit.
7. [MENTION=78854]Dark Lord[/MENTION] - Bumper, tire swing arm w/ hi-lift mount, ladder swing arm, bare metal, drop down hitch, camera relocation kit.
8. [MENTION=137886]Nico240[/MENTION] - Bumper, tire swing arm w/ highlift mount, dual jerry can arm, side ladder, black powdercoat, high clearance hitch, camera relocation kit, LOCAL pickup.
9. [MENTION=131300]Hawthorne[/MENTION] - Bumper, tire swing arm w/ highlift mount, bare metal, high clearance hitch, camera relocation kit.
10. [MENTION=137894]Burgermeister[/MENTION] - Bumper, tire swing arm w/ highlift mount, dual jerry can arm, side ladder, black powdercoat, high clearance hitch, camera relocation kit.
11. [MENTION=136709]Myron_[/MENTION] - Bumper, side ladder, black powdercoat, dropdown hitch
12. [MENTION=137928]SlateFalls[/MENTION] - Bumper, tire swing arm w/ highlift mount, dual jerry can arm, side ladder, black powdercoat, high clearance hitch, camera relocation kit.
13. [MENTION=119136]nmhyoti[/MENTION] - Bumper, tire swing arm w/ highlift mount, bare metal, dropdown hitch, camera relocation kit.
14. [MENTION=103959]cyclist[/MENTION] - Bumper, tire swing arm w/ highlift mount, dual jerry can arm, side ladder, black powdercoat, high clearance hitch, camera relocation kit. (2nd reciever)
Please double check your order and lmk if you need to change something.
Order Mod
After reading thru some of the Q's, It sounds like the drop down hitch can't hold 5000lb tow weight. If this is true, then I'll change my order to the Hight Mount Hitch.
Also, any thoughts on making a bike rack swing arm?
Status
peacefulpiranha
