Spacer lift question?
Fjatheart
First post and new to the site. I've got a 2003 Limited w/4.7 T4R. Is there a preference between the Daystar 2.5 spacer lift verses the Toy Tec 3 inch spacer lift? Does anyone know the pros and cons?
Thanks!
Daystar
Just put the Daystar on my 04 Limited v8. I don't know about the Toytec, but the Daystar 2.5/1.5 is a fairly easy install and is probably the cheapest on the market for that size of lift. I got mine for $141 w/ free shipping from autoaccessoriesgarage.com
Good hunting!
They all work the same way. Technically there's a difference in materials but I'm not sure it really makes a difference. Lift amount and price are the main differences, just look and see what you want. Also, I know Toytec use to provide us with forum discounts, pretty sure they still do. PM "Toytec Lifts" for more info.
I have a daystar lift, one of my freinds used a metal spacer lift. No difference either way. Get whatever is cheapest.
The daystar 2.5/1.5 is by far the most used spacer lift, as of recently. It is the cheapest, the easiest to install, and gives the customer the lift they want plus keeping a little factory "rake" in the front. I believe ive heard many testimonies that the 2.5/1.5 actually measures to a 3/2" lift. It allows you to run a 265/70/17.
The Toytec 3' spacer lift comes with a 1.5" rear spacer which imo evens out the gap in the wheel wells putting the nose a little high. This is the path i wanna take. Im lookin at either a Cornfed 3/1 or Toytec 3/1.5.
Good luck with your decision! :cheers:
So are you going with the Cornfed or Toytec because it levels the rake out a bit more than the Daystar?
Also, I've not heard of Cornfed, are they direct or sold via a retailer?
Thanks!
Cornfed do sell direct. But you can also order them from Burtman too. I just ordered mine from Cornfed, it should be here any day now. Hopefully it gets warm enough for me to start my mods that I have sitting for a while. Also on my way to get tires too, since the lift is going to leave quite a gap on stock tires, and since I need them too. The Dunlops are crap for me.
