spacer, OME, or Tundra/OME?
02yoyo
I bought an 02 sr5 about 6 months ago and after spending literally days on this and other forums I've got the itch to lift it up to accomidate 32's (265/75/16's, I think, it's been a while since I looked it up) I've heard 32's will fit without a lift but I want a lift. My delima is do I go with a spacer lift, the OME lift or the Tundra/OME lift. It's a daily driver so I don't wanty to kill the ride quality. I know any of these options will change the ride but which will change it the least or give me the most comfortable ride? After this set of tires I may add a body lift and some 33" tires but that's down the road a bit. Biggest reason for not going with the 33's now is gas mileage and loss of power. I had a 92 runner for 8 years so I am enjoying the extra Pep right now. Thanks for your suggestions.
If you just need an inch and you are on a budget you can get '99 coils from http://www.trademotion.com/partlocator/index.cfm?siteid=840&catalogid=0 and for a good price vs the dealership (by alot).
I have the bigger tires and I have no issues with rubbing and I still have room around the tire. I just replaced my shocks and coils for $380 shipped from Conicelli Toyota and I'm very happy with the stock ride and it does the job on the trails I ride and it doesn't give it too much lift that your girlfriend/wife can't get in;mine complains a bit since the tires give it the extra inch.
I'm really looking for more than an inch. I want at least 2 or 2.5. It looks really low because of the running boards and fender flares. That's why I want either the 2.5 spacer lift or the OME. I just don't know which would provide the best ride quality. I've heard the spacers make for a stiff ride but I'm sure the OME or Tundra/OME lift will stiffen things up a bit too. Just wondering which gives the best ride.
Spacers will never give the better ride vs better coils and shocks and it's worth it to go all out if you're going to go that far.
What's your measurements from the hub of the wheel to the fender flare lip? Front and rear?
OME is the way to go for what you sound like you want, great ride and has everything you need, nice shock's also... have pics if you want to see the flex/poser shots
Runner up. You would choose all OME over the Tundra/OME setup? How difficult is the instalation for the OME coils and shocks? I have access to a garage with all the tools I would need shy of a spring compressor but not much mechanical ability. Would I need the Diff drop kit with the OME setup?
