Spacer question 3rd=4th
lbrunner
Anyone know if a 3rd gen spacer will work on a 4th gen? I have spacers that are 3/8 thick made for my old 3rd gen 4runner that I never installed. Wondering if they would work on my 4th gen. They were made to give additional .50 lift for the OME coils I think. Been awhile. Any ideas? I just was thinking of taking some of that front end dip out with something I already have.
Go online & cross check to see if the part # is the same.
If so...then there's your answer.
On other cars...I always use online search as Kragen to see if Toyota & Lexus have the same part #
spacer
I have know idea what part# this is. Nothing on the spacers and I think this was a custom fabricated to add a slight lift. I have to do more checking on yotatech where I used to get all my info on my 3rd. I had OME lift, drop diffs, pan hard rod bracket installed on it. Just thought maybe someone knew off the cuff if the front strut setup was same as 3rd gens, then this spacer would work. I'm not sure if it would be worth it to add as its only 3/8 thick which I think doubles to 3/4 inch. Thanks
