Spare key fob programming question?
beewee
I have been looking but can't find instructions for reprogramming a key fob. The plastic case on mine broke and the "spare" doesn't work so thought I would try to reprogram it with a new battery. Anyone have the instructions? Plus they are different cases so it can't be that easy.
Thanks a bunch!
I hope everyone is having a wonderful Valentines with your trucks too!
B
FOB Programming
B - I bought a used fob for my '05 and was able to reprogram it. Unfortunately, I didn't save the instructions. Quick google on Toyota Key Fob Reprogramming showed the below steps; can't remember if this is what I did, but I do recall it was a wierd combo that made me think I should stand on one foot while doing it, just for good measure:
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Good luck, Gordo
