Spark knock/pinging
Mass 4runner
Just turned 95k on my 2010 and I'm hearing a very slight pinging at low rpm light throttle conditions. It's not all the time, and it's mild enough that you have to strain to hear it. But it is there. Anyone experience anything similar? If so, did you correct it and how?
But goes away with higher octane fuel I presume?
I think with that type of mileage, a dirty throttle body, intake and blackened 02 sensors are all thats necessary to make conditions ripe for the electronic engine control management to be strained enough under loads where pre-ignition can occur with lower quality fuels. Just because 02 sensors are not throwing codes doesn't mean that operationally they are anywhere near doing what they should be doing. Just my un-professional opinion of course but I've had a few vehicles through the years with the design characteristics of these trucks (V6's and V8's) where a general cleaning of the entire intake and fresh 02 sensors cured any signs of hesitation, poor performance and fuel mileage, and pre-ignition issues. While you're doing that - can't hurt to change plugs too, proper gap is critical, OEM plugs only. :thumb:
What fuel are you running. Does it go away with premium?
Does not sound like knock to me.. Typically not a light throttle thing, but it is possible.
More likely something in the accessory drive system...
Thanks for the replies. This has only been happening for the last week or so. I'll try going to a higher octane first. Probably should have done this already before posting about it.
I have the same issue, 91k, premium fuel.
Only knocks at lower rpm, I wouldn't call it a ping, more of a knock, light to no throttle. I only notice it once in a while.
No performance issues, MPG's is the same as it ever was..poor to marginally decent (16-20 (20 on a good day))
youngrk
