Spark plugs and gaps
ShooterMcGavin
I'm getting a misfire, no CEL, but it can be bad at low RPMs under power (like taking off from a stop on a hill). I'll be doing a big tune up, without the valve adjustment. New plugs, wires, and a lot of other stuff. So...
I've read that our plugs need to be gapped at 0.043" (1.1mm). If my gap tool only does 0.040" or 0.044", should I go for the tighter tolerance? Is that close enough to not cause any issues? As the ground wears down, does the closer tolerance give me a little more life in the plugs?
I've read people saying "you must gap your plugs" and others saying "do not gap your plugs out of the box or you will ruin them"? What the...?
When I was young, my dad showed me how to gap plugs. We would take the plugs out, clean them, gap them, and put them back in. Have things changed as far as this is concerned? I don't hear about people re-gapping their plugs any more; people buy new ones. Why can't I take my current plugs out, re-gap them, and use them longer?
I will be using double-ground platinum Denso plugs.
if you buy toyota plugs they are pre-gapped out of the box i presume you have a V-6. 90919-01192 are the toyota plugs should be 3.13 each from the dealer.
Gap the plugs to .044. Use new ones, they are only plugs.
How clean is the MAF, TB and IAC?
MAF and TB were just cleaned. I will be taking the TB apart when I do the tune up to clean it more thoroughly and clean the IAC. Also, I have a cloth/oil filter. I made sure to clean/oil the filter and drive it for about a month, before cleaning the MAF.
Just had issue with missing when first started during humid conditions - no CEL and it would pass in a few minutes. I had installed standard copper plugs 60,000 miles ago and gap was worn (my bad - should have been replaced at 30,000). I installed double platinum NGK's (should go 60,000)- they are pre-gapped....did not need to touch them. Also installed Denso spark plug wires and new Denso boots for the coil-on-plugs (may not have needed these but wires were done 5 yrs ago and never have replaced the coil boots). Cost $96 delivered from Rockauto (using the 5% discount). Running perfect at 227,000 miles.....
Parts......
2000 TOYOTA 4RUNNER 3.4L V6
Ignition : Spark Plug (6)
NGK Part # 4302
{#BKR5EKPB11} Laser Platinum
.044
Ignition : Spark Plug Wire (1)
DENSO Part # 6716182
5mm; Boots not included
Ignition : Spark Plug (Coil-On-Plug) Boot (1)
DENSO Part # 6716248
3 Boots
Buckaroo
