Check out the Aussie I just installed mine a week ago $313 shipped... Tried it out yesterday and it works like a champ... I tackled a few obstacles that I know would've gave me issue and when my back started to slip I felt the other kick in and it nudged me right over no problem
Where did you order it from
I've run Aussies and Lockwrongs in the past in all my Toy axles. They work fine for a while until the teeth, pins and springs or a combination of those begin to wear out. That will be determined by how strongly you shock load them throughout their life. Run the Spartan. The pins are bigger, stronger and the unit itself is smidge easier to set up IMO. There are a bunch of guys I wheel with that have all switched to Spartans after blowing up Aussies and LockWrongs and have yet to have an issue since making the switch.
Good to know I think if I blow it up I'll replace it with an ARB... I'm just poor ATM and wanted to give it a try
i also just put an aussie in last week to hold me over till i can afford my arb lockers and from all my research more people liked the aussie better and they have a better warranty. ive never done any diff work and it was a breeze to install and functions great.
only time will tell how it holds up.
Hey man I was wondering if you could look at this write up and let me know how close the Aussie locker is for install??? Here is the link:
Lock-Right install guide
The install is pretty simple and staraight forward. My buddy had a lockright in his taco for 3 years before he had to replace it. He sheared 2 center pins before the locker itself gave out so yes they are strong
ya its exactly the same just using different manufactures parts.
this is the aussie install guide i used
http://www.toyota-4runner.org/3rd-g...-rear-differential-installation-write-up.html
if you have any questions feel free to ask.
Agreed. Stay away from Lockrite, they suck. Aussies are better, but Spartans are cheaper and stronger.
I've been researching this as well as of late. From reading reviews and threads all over the place i'm seeing the same thing. A lot of guys on Pirate are even running the Spartan over the Detroit do to ease of install and affordability. Its alot easier to replace a drop in locker on the trail than a full carrier locker.
I think this is the route I am going to go on my rear 44. Maybe save Kevin a little money too!!!
Actually My dad has run the Lock Right for years in his jeeps and hasn't had a lot of problems. Especially with the smaller motors. The only time he has had any issue was running one in an AMC 20 turned by a 350 chevy with a low gear kit. I don't think my 3.4 will have any issues!!! But haveing said that with Spartans price thats the way to go!!!
I dunno if it's the right call for you though - Spartan says don't go bigger than a 32, and you've got a heavy foot. I still think you should ditch the idea of an automatic and either weld it up or go with a full spool.
You just want me to weld it so you can get my axle cheaper :suspicious: I see how you are!!
