SPC Control Arms; Backspacing
Stock wheel BS work, if that's what you mean.
Slide the upper ball joint all the way to the out-side. On the SPC UCA.
Just trying to see if it requires less backspacing over JBA’s arm. JBA arm sticks out pretty far and required me to run a 1.5” spacer which is un ideal. Now I hit the fire wall majorly
I did, i should’ve phrased my question “what backspacing are you running with SPC arms”
The answer I got was it will work with factory wheels
Sucky response. If there is some measurement I could provide off of mine, let me know
Your over thinking it.
You won't need spacers.
Mudder tires might get close to the UCA at full extension.
Snow chains might not fit.
